Building brake pressure
Old Apr 15, 2019 | 03:17 PM
7898regency's Avatar
My 78 98 will build brake pressure in nuetral or park while running but as soon as I put it in drive or reverse there is nothing. You guys have any suggestions?
Old Apr 15, 2019 | 04:59 PM
I suspect you are experincing a low vacuum issue with the brake booster. Use a vacuum gauge connected to a port on the intake manifold to verify there is sufficient vacuum when the transmission is in gear.
Old Apr 15, 2019 | 05:14 PM
Thanks I will try that
Old Apr 15, 2019 | 06:45 PM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
Yes, low vacuum is the likely culprit.
-Check the line from the intake or carb to the booster.
-Verify the check valve (and its rubber grommet) in the booster is in good shape and allowing air flow in one direction only.
-The seal(boot) between the master cylinder and booster is known to fail after 40+years.
-Lastly, the booster bladder itself could be shot, Replacement or rebuild is two options if it's bad.
Corswiki
Apr 10, 2019 07:29 PM
rodan
Jul 19, 2018 07:29 PM
zodiacblueS
Brakes/Hydraulic Systems
44
Oct 12, 2014 03:22 PM
63super88
Mar 18, 2014 02:03 PM
johns59super88
Nov 25, 2013 11:08 AM
