Fox body M/C question (yes, Olds-related)
Old Apr 21, 2019 | 06:02 PM
I picked up the manual brake master cylinder from a 79-83 Fox body to use on my 62 F-85, due to the starbord outlet location and the 7/8" bore. I need to modify or replace the pushrod that came already attached. There is some sort of plastic retainer holding the pushrod into the back of the M/C. Anyone know the trick to getting this out? Does it simply snap in, or is there a retaining ring I'm not seeing? I don't want to break it getting it out. Thanks.
Old Apr 22, 2019 | 04:32 AM
Joe, I tried to do a search on your problem and only came up with hits on vintage Mustang master cylinders. Here's one of the threads:
https://forums.vintage-mustang.com/v...-cylinder.html
Is there a snap ring holding the piston in the master cylinder? If so, I would start by taking out the snap ring and removing the rod and piston from the master cylinder.
Old Apr 22, 2019 | 05:25 AM
Yeah, I did that before I asked the question here. I haven't been able to see a snap ring, but I haven't had time to look that closely yet.
Old Apr 22, 2019 | 03:05 PM
mpolds's Avatar
For a guy who doesn't work on cars, I Have your answer....
It is backwards to what you think is normal...
Lock the push rod in the vise -- and knock the master cylinder off the push rod --
Rather than visa versa.
The master cylinder will then separate from the push rod.
Yours, Craig....
Leaving tonight for Carlisle -- see you there --. I I. 118 -, 119..
johnnyrockets
Brakes/Hydraulic Systems
Mar 12, 2019 06:10 AM
zeeke
24
Apr 18, 2018 10:53 PM
Fox Stuart
May 31, 2017 11:08 AM
ilandtime
Mar 10, 2014 09:25 PM
Mr Shifty Sidney
Jun 12, 2013 12:06 AM
