Fuel Pressure, Line Sizes
Old Aug 10, 2009 | 01:57 PM
Creativeindy's Avatar
Arrrggggg
How much Fuel Pressure does a 1970 Cutlass have?
350 4BBL motor.
Reason I ask is, the fuel pump on my 69 has 5 - 7 1/2 PSI but for some reason, when I went to replace mine, the new one has a 5/16th Fitting that goes from pump to carb, where as the old one that was on the motor has a 3/8th's fitting. Seems the new 68 and 69 both have a 5/16th Pump to Carb fitting at the pump from my investigating.
I was curious if the 70 replacement pump (Which does have the 3/8ths line fitting) pushes the same amount as the 69 which is 5 - 7. Didn't know if I could use this pump or what. Trying to find a 5/16th fitting to use on this new pump is almost impossible at the 20 places I've been to and the few online stores I've called don't have it either.
Del70
Dec 7, 2025 02:13 AM
Del70
Sep 11, 2012 06:45 AM
71supreme
Mar 6, 2011 12:24 PM
davepnola
Dec 2, 2010 09:00 PM
68conv455
May 20, 2008 02:03 PM
