Flywheel bolts
Old Jan 30, 2017 | 08:21 AM
Napoleon1991's Avatar
Flywheel bolts
Im converting my 69 cutlass to a 4 speed. I forgot to order flywheel bolts since I didnt realize that they were longer than the flexplate bolts. Is there any reason I can't go to the hardware store and get grade 8 bolts that fit, or are they special bolts?
Old Jan 30, 2017 | 08:54 AM
2blu442's Avatar
Are these the flywheel to crank bolts? I'm not an expert so someone will have to speak up who is. But I'm picturing bolts with a thinner head than off the shelf bolts. If that's correct, the hardware store bolt heads may be too tall and interfere with the clutch function. I'm leaning towards specialty bolts for the flywheel to crankshaft. But again, I'm sure there's someone here who knows for sure. John
Old Jan 30, 2017 | 09:06 AM
yes, they are the flywheel to crank bolts.
Old Jan 30, 2017 | 10:19 AM
You should be able to get the correct flywheel bolts from an auto parts store or speed shop.
http://www.oreillyauto.com/site/c/de...0878&ppt=C0377
http://www.autozone.com/transmission...ex-plate-bolts
Old Jan 30, 2017 | 02:58 PM
Yellowstatue's Avatar
Does your crankshaft have the machined hole for the trans support bearing to fit into?
Old Jan 30, 2017 | 09:03 PM
Spent most of the day looking for a store that had them in stock. Finally found them. Thanks for the replies.
Old Jan 31, 2017 | 06:19 AM
Run to Rund's Avatar
ARP makes them in various lengths (for different nominal applications) to match different thicknesses of flywheel flange.
Old Feb 2, 2017 | 06:52 AM
brownbomber77's Avatar
I think I'm using SBC ARP bolts for mine, they're either .750 or 1"
Old Feb 2, 2017 | 08:44 AM
NOS flywheel bolts are 7/16x20x0.87" long. ARP 240-2801 are .875" long. ARP 200-2802 are 1", 350-2802 are .925" long.
Old Feb 2, 2017 | 09:32 AM
droldsmorland's Avatar
CH3NO2 LEARN IT BURN IT
ARP is the ONLY thing I would install in a critical fastener area such as this, that is unless you find NOS OEM. Guarantee the hardware store "grade 8s" are chineasium junk. Think about the job those fasteners are doing especially at 5-6 grand on a hole shot. Safety first. A flywheel coming unglued at 6K can take your feet off unless you have a scatter shield.
Old Feb 2, 2017 | 09:40 AM
oldsmobiledave's Avatar
Pilot bearing
Are you sure that your crank is drilled bit the pilot bearing?
Old Feb 3, 2017 | 12:29 AM
crank wasnt drilled. Had to remove it and have a shop drill it.
Old Feb 3, 2017 | 07:21 AM
I strongly recommend a steel aftermarket flywheel, SFI approved clutch to prevent blow-up, and then a blow proof bellhousing like Lakewood or, better, a Quick Time.
Old Feb 3, 2017 | 08:09 AM
I am using a centerforce billet flywheel and centerforce clutch but i have a stock bellhousing. I have heard that the blowproof bellhousings need some modification on an oldsmobile. Is this true?
Old Feb 3, 2017 | 02:15 PM
The QuickTime works as supplied. The Lakewood has an ear at the starter pocket that interferes with the clutch linkage, has been so for 40 years or so, and they aren't smart enough to realize you would want to run a clutch linkage. Everyone just cuts off the ear.
Old Feb 3, 2017 | 02:30 PM
1970-W30's Avatar
The shoulder dimensions of the flywheel bolts is critical, don't trust a bolt just because the length and thread pitch matches. Get the ARP flywheel bolts and be safe.....
just saying.
Old Feb 4, 2017 | 07:31 AM
Stock and ARP flywheel bolts have more bearing surface on the flywheel, with 3/4" heads instead of the normal 5/8" for standard bolts. Also, the flywheel bolts have thin heads to clear the clutch disc hub.
stanzaschance
Jul 28, 2015 06:38 AM
Sampson
Dec 28, 2014 07:41 AM
nolabigdawg
Oct 25, 2014 11:50 AM
Oldssupreme
Feb 6, 2013 12:39 AM
Eddie Hansen
Mar 23, 2010 11:49 AM
