First start of the car, carburetor over flooding?!
Old Oct 25, 2014 | 11:15 AM
Teamcamber's Avatar
Hi!
Today the first test run of the engine was done. The car has been sitting for maybe 4 years. But I havent touch the engine, more then sparkplugs, oil and som more stuff.
First run was okej, it worked as it should. We then started it a few times and everything was fine.
One hour later, when I start the engine it was going about 15sec before it dies. Next try is the same, the engine is runner for about 15sec then it dies.
Some gas was dripping around the carburetor from the air filter.
Whats my next step? Is the needle stuck or what do you think?
Hope you understand what i mean.
Old Oct 25, 2014 | 11:20 AM
Octania's Avatar
Dirt in the needle/ seat
easy fix
Old Oct 25, 2014 | 09:21 PM
redoldsman's Avatar
Proud Viet Nam Veteran
While you are working on this please have a fire extinguisher close by. Don't ask me why I tell you that but you probably would get it right on the first guess.
Old Oct 26, 2014 | 07:33 AM
76olds's Avatar
Hookers under Hood
You could try to lightly tap the top of the carb with a hammer, then start it up.
Hope this helps
Eric
Old Oct 27, 2014 | 12:26 PM
Teamcamber's Avatar
Problem fixed, dirt in needle, thx!!
Old Oct 29, 2014 | 04:26 PM
jerseyjoe's Avatar
New gas does not help for sure. May want to pull the top off of the carb and clean the bowl (if you did not already).
Professur
Sep 9, 2014 09:10 AM
JohnnyBs68S
Aug 11, 2014 06:51 PM
Dshelvy
Jan 5, 2013 09:09 PM
VikingBlue
Feb 14, 2011 07:34 PM
Red Delta
Apr 9, 2010 08:31 PM
