Exposed Cylinder Block
Old Sep 4, 2013 | 05:45 AM
tgilligan's Avatar
Hey Guys,
In the process of a teardown and just removed the heads so that I can have them machined and new components installed. My concern is the exposed cylinder walls/block. I'm 2nd owner and this looks like the first time heads have been removed, decent amount of carbon build-up but overall in very good shape. Anything I should do to protect the open cylinder bores?
Original intention was only to have the heads off a few days while the work was done but budget didn't allow it so now it's going to be a couple/few weeks and I don't want to damage the block. It was bad enough that some coolant got into the cylinders when the heads were removed but I was able to get all visible traces cleaned up, so I don't want to compound the problem. Anything I should be aware of, steps to take or will it be okay sitting open until I get the heads back? A sidenote is the engine was not removed so it's still under the hood. I've attached a pic for reference of the current state.
Old Sep 4, 2013 | 06:07 AM
Rub the cylinder walls down with some oil, and lay a towel over the engine to keep the critters out.
Old Sep 4, 2013 | 06:14 AM
^^^This. Just don't be surprised when you get some oil smoke out the exhaust upon initial startup. It will burn off quickly.
bocoogto
Aug 26, 2023 06:09 PM
olds4life
Feb 9, 2010 08:48 AM
davepnola
Dec 18, 2009 05:50 AM
NEWOLDSMAN
Nov 17, 2009 12:19 PM
