Exhaust Manifold Gaskets
Old Aug 21, 2020 | 03:28 PM
Neuby7297's Avatar
Can Anyone Recommend a brand or part number for some Exhaust manifold gaskets? I have FelPro on there now. I tightened down a little. Still a little leak. Want metal gasket. I have a 72 Cutlass Supreme. 350 Rocket. 4bbl
Old Aug 21, 2020 | 05:56 PM
Remflex. Steel core graphite. The best I've ever used. Just pay attention to the torque spec. If you overtorque the bolts and crush them, they are worthless.
Old Aug 22, 2020 | 04:31 AM
Neuby7297's Avatar
Thank you! I’ll look them up and get a part number.
Old Aug 22, 2020 | 05:52 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I have actually used Permatex Optimum Grey RTV with or without gaskets to seal manifolds. My 5.9 Dodge had a broken bolt and no gaskets, it still sealed. I used it with Cooper gaskets, Optimum Grey on both sides to get rid of an annoying leak on my Olds 350. It is much firmer and more conspicuous than Ultra Cooper and good to 700 degrees Fahrenheit. Olds didn't use gaskets from the factory but we saw the occasional one come in leaking. Your surfaces are probably less than true causing the leak.
Old Aug 23, 2020 | 07:32 AM
ELY442's Avatar
I have no problem using FelPro exhaust manifold gasket. I apply a small bead of Permatex RTV High Temp Silicone on both side of the gasket, let it cure for a few minutes, slide it in and bolt it up.
Rafabaldi
Oct 16, 2018 12:23 PM
Oldssupreme
Sep 7, 2016 09:46 AM
ChrisM
Mar 19, 2015 08:57 AM
sixty9olds
Jun 20, 2012 09:37 AM
toneypenna
May 24, 2009 07:08 PM
