Engine Oil Fill Tube
Old Mar 28, 2018 | 03:51 AM
Christopher Michael Drew's Avatar
Hey guys, since I got my 71 Olds 350, there has been no oil fill tube. a previous owner closed it up. My question is why would someone close it up? I see aftermarket fill up tubes online(like this: https://www.yearone.com/Product/1964...71#prettyPhoto) and I don't see threads, do you simply just stick the oil fill tube into the hole? and if you do just stick it in, how does it say secure? Let me know what you guys think. Thanks!
Old Mar 28, 2018 | 04:02 AM
It's just a tube isn't it? On the front of the block. If you don't have one there must be a hole for it or did he plug it with something? My tube on my 71 comes out easy but I tried to get the tube out on a junk 72 block I had and it wouldn't come out. I'm sure you can get one still, they were used on the Olds up into the late 80's.
Old Mar 28, 2018 | 04:14 AM
Yeah he plugged it up. Before I buy one I want to make sure there not notorious for coming lose or oil leaks or whatever.
Old Mar 28, 2018 | 04:54 AM
RetroRanger's Avatar
72 Olds CS
They are just a press fit. To remove I usually wrap the tube with a strap and pull the strap up with a hoist. With upward pressure on the tube I Then I tap around the tube w 2x4 pieces and if your careful it removes w no damage. To install I place the tube in its hole and rest a 2x4 piece on top of the tube, I then hit the 2x w a rubber mallet if your careful you will not damage the tube when installing.
Old Mar 28, 2018 | 05:02 AM
BillK's Avatar
Chris,
There are usually a couple of NOS GM ones on e-bay. I dont know how good the aftermarket ones are but I just finished the 307 in my Wife's car and I bought a NOS GM one for less than what the aftermarket ones are. I had to beat hers up pretty good to get it out to clean the block and did not feel good re-using it.
How have you been putting oil in yours ? Through the pcv valve hole ???
Old Mar 28, 2018 | 05:03 AM
Thanks Retro the info!
Old Mar 28, 2018 | 06:49 AM
Removing the oil fill tube makes it easier to pull the intake without pulling the distributor. People sometimes do this if they have aftermarket valve covers with an oil fill provision.
Old Mar 28, 2018 | 08:36 AM
droptopron's Avatar
delete
Originally Posted by BillK
Chris,
x2 on the Repro. I'd look for a good used or an NOS They can't be hard to find
Old Mar 28, 2018 | 08:57 AM
As long as there is a fill opening in a valve cover, I'd just leave it off. BTW, have you updated your other threads on the fixes for those issue?
Old Mar 28, 2018 | 10:35 AM
Bill, I just put oil through the breather hole, its a slow process, but it works.
Oldcutlass, what do you mean have I updated my other threads? Like did i tell everyone the issue is fixed?
Old Mar 28, 2018 | 10:38 AM
Yes, and/or how you fixed it for future members who may have the same issues.
Old Mar 28, 2018 | 10:41 AM
Okay ill do that now!
Old Mar 28, 2018 | 04:58 PM
Sampson's Avatar
Funny you bring this up now Chris. I just opened the box from Summitt for this filler tube. It is made by March performance. Summit p/n MCH-16012.
Looks like a nice piece. Billet Aluminium with O Ring seals on the base and filler cap. Yes the Original is a press fit. Mine original leaked until I sealed it with permatex. I will let you know how it fits after I get it installed.
Old Mar 28, 2018 | 05:13 PM
72 Olds CS
That looks nice Sampson...I think it would make the rest of my engine feel bad if I put that on my car
Old Mar 28, 2018 | 07:41 PM
That looks very nice Sampson, yeah tell me how it holds up when its running.
Old Mar 30, 2018 | 07:48 AM
olds 307 and 403's Avatar
Out of Line, Everytime😉
The top cap threads in correct? I saw that one but have a feeling the old one will suck to pull out. The oil fill tube is one of the dead give aways of the Olds V8 and it is not the same without it.
daves62
Jan 13, 2013 02:28 AM
68Tom
Jul 10, 2009 08:07 AM
344870M
Apr 11, 2009 08:55 AM
tkw31
Apr 10, 2009 04:04 PM
Lou
Apr 19, 2008 06:19 PM
