Engine Install
Engine Install
I have a 1968 Cutlass, convertible, 350 Olds motor. I am installing the motor, can I install it with the headers on? or do I need to install the headers after installing the motor, automatic car, with AC.
nother tip is to leave the motor mounts loose on the block. Once you have the headers on and Motor Mount thru bolts installed, then tighten the motor mount to block bolts. then tighen the thru bolts
Gives you much more wiggle room
This is the way to do it - I have done this multiple times and can't even imagine trying to get the headers in after the engine is in place. Why make it harder than it needs to be?
X3 i also install the oil filter later and starter.I also use a mini starter much easier to get in and out.
2blu442
November 10th, 2012 10:16 AM
