Engine Install
Old Apr 22, 2016 | 11:50 AM
WackyTacky's Avatar
Cool Engine Install
I have a 1968 Cutlass, convertible, 350 Olds motor. I am installing the motor, can I install it with the headers on? or do I need to install the headers after installing the motor, automatic car, with AC.
Old Apr 22, 2016 | 12:06 PM
Install them after, they will get in the way as the engine goes down. Its easier if you raise the car up high so you can have plenty of room to swing them up.
Old Apr 22, 2016 | 02:53 PM
BlackGold's Avatar
But once the engine is hung in the bay you might want to attach the headers before bolting the engine in place and removing the hoist. It gives you options.
Old Apr 22, 2016 | 03:13 PM
AzMotorhead's Avatar
nother tip is to leave the motor mounts loose on the block. Once you have the headers on and Motor Mount thru bolts installed, then tighten the motor mount to block bolts. then tighen the thru bolts
Gives you much more wiggle room
Old Apr 22, 2016 | 03:14 PM
Very true, sometimes you have to lift one side or the other to get them into place with a couple of bolts.
Old Apr 22, 2016 | 06:48 PM
WackyTacky's Avatar
Thank you!
Wanted to say thanks to all of you, great to have those with experience have your back!
Old Apr 22, 2016 | 11:01 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I found it fairly easy to install the motor with the headers sitting in the engine bay. I just wired them out of the way. Much less wrangling to get them in place.
Old Apr 23, 2016 | 01:01 AM
This is the way to do it - I have done this multiple times and can't even imagine trying to get the headers in after the engine is in place. Why make it harder than it needs to be?
Old Apr 23, 2016 | 02:51 AM
wr1970's Avatar
X3 i also install the oil filter later and starter.I also use a mini starter much easier to get in and out.
gunmetal71
Jul 6, 2015 02:58 PM
george landis
Apr 28, 2015 06:30 PM
NightStalker
Apr 29, 2013 08:40 AM
2blu442
Nov 10, 2012 10:16 AM
805cut
May 3, 2012 08:11 PM
