Engine cuts out
Old Mar 15, 2015 | 08:18 AM
ollerich29's Avatar
Engine cuts out
I have a 70 cs with a 350 2bbl and I got it out of storage yesterday, and when I drove it home it would cut out and back fire. I would let off the gas for a few seconds and then get it back to 55 60 mph and it would usually come out of it. It kept doing that about every 5-10 miles. It did that last year a few times mostly under acceleration and just once cruising. Any help is greatly appreciated.
Old Mar 15, 2015 | 08:54 AM
Octania's Avatar
you are able to get out of storage in March?!
Sounds like fuel starvation
clogged filter
crud in the carb occasionally blocking the jets
or perhaps age old rubber lines in the tank to pump run, leaking air in.
Old Mar 15, 2015 | 08:58 AM
CutlassDad's Avatar
Sounds like a fuel issue, that is it runs 'til the float bowls are dry, cuts out and repeats. I've seen an electrical problem act that way, but it was just a "blip" cutout and recover. The fact that it takes time to recover rules out electrical problems.
Old Mar 15, 2015 | 06:48 PM
ollerich29's Avatar
It was about 30 degrees above normal here in Sioux falls couldn't resist. No fuel leaks did replace the filter looked like some one painted it the color of rust, but no flakes in it. Haven't taken it back on the highway yet but running good around town. It has the original tank and I'm thinking might need to get a new one in the future.
Old Mar 24, 2015 | 03:16 PM
ollerich29's Avatar
Turns out I have a leaky fuel pump didn't see it with the motor off. I had it warming up in the garage and when I backed it out saw a nice big puddle on my floor. I haven't pin pointed the leak yet but probably will just replace since they are inexpensive.
Old Mar 24, 2015 | 04:49 PM
Are you sure it's not the fuel line?
Old Mar 24, 2015 | 06:05 PM
If it is the fuel pump, you may need to change the oil as the leaking fuel may have drained into the crankcase.
Old Mar 25, 2015 | 07:34 AM
ollerich29's Avatar
Yeah I re tightened them after I got it back to my garage. Thanks for the heads up about the oil.
Old Mar 26, 2015 | 01:28 PM
ollerich29's Avatar
I believe it is leaking from where the pump attaches to the motor so I am thinking of just replacing the gasket and go from there. Anyone have any tips when replacing?
Old Mar 26, 2015 | 07:24 PM
redoldsman's Avatar
Proud Viet Nam Veteran
A leaking gasket where the pump attached to the block will not cause a miss. It will just cause an oil leak. Don't overlook a bad coil. It doesn't happen often and usually takes a long process of elimination to find it. It is one of those things that will drive you nuts if it is the problem. What Fun71 is talking about is the fuel pump leaking fuel internally into the crankcase. Replacing the pump is the only solution. A standard fuel pump is pretty cheap.
Old Mar 27, 2015 | 06:59 AM
ollerich29's Avatar
Would there be any other symptoms if it is the coil. Also I haven't checked the oil yet but it is an external leak.
Old Mar 27, 2015 | 07:04 AM
Pretty much exactly what you describe. Either that or the condenser, or possibly a bare spot on the wire to the points, inside of the distributor, that touches ground on occasion.
Old Mar 27, 2015 | 07:10 AM
There is still the issue of the puddle of fuel on the floor. I would still be searching in that direction.
Old Mar 27, 2015 | 07:46 AM
ollerich29's Avatar
Yeah regardless of what is making the motor cut out I will need to get the leak fixed so I can at least drive it again.
Old Mar 27, 2015 | 07:54 AM
The leak and your issue may be related. Did you check your lines?
Old Mar 27, 2015 | 10:43 AM
ollerich29's Avatar
From what I can tell the lines are good. But it's hard to tell with the alternator on.
Old Mar 28, 2015 | 12:25 PM
ollerich29's Avatar
Anyone know what the fuel pump should be torqued to or does it matter? Also, it was leaking from where the top meets the bottom, not sure of the technical terms for them.
Old Mar 28, 2015 | 12:29 PM
Just make it tight, but not too tight.
And that's a weird place to leak from.
The hoses weren't dry or cracked, were they?
Old Mar 28, 2015 | 01:37 PM
ollerich29's Avatar
No they aren't. Both the inlet and outlet connections were dry, but right under that lip all the way around the pump is wet.
Old Mar 28, 2015 | 01:40 PM
Okay. Sounds like you got that fixed.
It could be the cause of your cutting out, but it could be an electrical problem - only way to tell is to try 'er out!
ollerich29's Avatar
Not just wet but dripping wet.
Old Mar 28, 2015 | 01:43 PM
Sounds like the diaphragm is leaking, did you replace the pump?
Old Mar 29, 2015 | 09:03 AM
ollerich29's Avatar
Got a new pump in yesterday no leaks, and so far she runs smoothly. Thank you all for your input.
Old Mar 29, 2015 | 11:47 AM
navvet's Avatar
ollerich29....I have exactly the same issue with my 64 dynamic 88 2bbl 394. AND YES I GOT IT ON ROAD YESTERDAY AS WELL>>>YAHOO. Streets were swept and it had rained hard the last week so I felt safe driving in March. ( Miracle in MN)
My fuel pump is new, fuel lines new, tune-up 3K miles ago. Carb rebuilt...timing is spot on.
I can travel 200 miles w/o issue and then bang..CUT OUT.
Yesterday it drove fine....then after 20 miles bang ..CUT OUT. Help again>
Old Mar 29, 2015 | 12:50 PM
If you look at your old fuel pump, you will see that any leak past the rubber diaphragm will likely result in fuel getting into the cavity in the mounting flange. This means fuel in the crankcase, so an oil change may be necessary.
84oldsDelta88
20
Jan 12, 2016 01:36 PM
crank shaft
Jun 3, 2014 06:53 PM
starfire
Feb 20, 2013 03:26 PM
805cut
May 3, 2012 08:11 PM
Texas Jim
Ninety-Eight
17
Dec 30, 2009 06:28 PM
