Engine break in
Engine break in
I want to make sure I have everything straight for breaking in an engine. I use break in oil, prime the oil system, and run the car for 20 minutes at 2000-3000 rpm, varying the speed. I then drive 30-50 miles doing vacuum pulls. The oil is then changed. I then go until I hit 500 miles. The oil is changed again and the car is driven normally until 1500 miles when the oil is changed again. Does this sound correct? Also, can I start using regular oil at 50 miles or do I still need break in oil until 500 miles? Thanks.
Couple other things I do is, I use just water, no anti freeze, so if I have a problem or leak, I don't have anti freeze all over and waste it. I also have a large box fan, in case the engine runs hot, also fire extinguisher, also I like some one to help me so they can watch the gauges, and the I can also check, and change the timing if needed.
Si agree except for one thing, leave the break in oil in for more than 20min. The zinc in the oil also helps break in the rings consequently potentially improving ring seal as well. Driven recommends 400 miles before a change.
