Engine balance question
Old Jan 14, 2013 | 05:34 PM
coppercutlass's Avatar
Chevy budget Olds powered
Well i scored a free engine that was balanced for a flywheel. Now i run an automatic. If i have the engine's balance checked will it affect it from running a flex plate to a fly wheel or can wheight be added to the flex plate to match the original balance. The engine is a 355 with probe pistons i plan on sending this engine out and having it gone through since it was free and a really good starting point for a procomp aluminum headed small block build.
Old Jan 14, 2013 | 05:57 PM
cutlassefi's Avatar
If you're having it checked then it may or may not need to be rebalanced.
A good shop can balance the flywheel and flexplates to the same imbalance. Thereby getting the same results.
Just have it checked and go from there.
Old Jan 14, 2013 | 05:59 PM
Cool thanks. This engine will be sent out the previous owner had a very reputable shop to the work and it shows im not about to mess that up lol.
garys 68
Wheels and Tires
36
May 18, 2017 11:18 AM
gearheads78
Oct 9, 2010 08:53 PM
sammieolds
Aug 10, 2010 02:49 PM
coltsneckbob
Wheels and Tires
Apr 9, 2010 12:36 PM
