Engine back in, having some problems
Old Apr 17, 2011 | 08:25 AM
69350rocket's Avatar
Well I got my engine back in a few days ago. I kind of just wanted to see what pistons I have. Turns out they are the big dish kind unfortunately. But anyway I had the heads milled a bit and had the carb tuned. Got the engine back in and the transmission is barely operating. Seems like a vaccum problem. It will only work every now and again. Sometimes I rev it and it does nothing, and sometimes it will move. One time I tried driving it down the road and it wouldnt shift. I checked the vacuum line down to the modulator. I took it off and put my finger up to it and it had plenty of vacuum. I cant figure out what the problem is.
Old Apr 17, 2011 | 09:17 AM
Rickman48's Avatar
Have you checked the trans fluid?
If any leaked when you pulled the motor - - -
And if the converter didn't 'seat' in the pump - - -
Old Apr 17, 2011 | 12:03 PM
Well, the converter thing makes sense. When I was tightening the converter to flexplate bolts I noticed the converter did draw forward with it a little bit. I dont know why it would do that though.
Old Apr 17, 2011 | 03:56 PM
Rickman48's Avatar
I've seen where some installed the flexplate backwards - there is some concave/convex situation there.
I usually look for the marks of the boltheads to get it right!
Old Apr 17, 2011 | 06:30 PM
OLD SKL 69's Avatar
GM Enthusiast
x2
Old Apr 17, 2011 | 06:48 PM
x3
Sounds like low fluid to me.
Old Apr 21, 2011 | 04:09 PM
Im still fighting this problem. I took all the bolts off and pulled the converter back. When the converter is pulled all of the way back in, there is about a 1/4 inch gap between the converter tabs and the flexplate. Im guessing that this is causing my problem? Should I shim the gab a little bit? I dont understand why it is doing it now, there were no washers shimming it before? And no, the flexplate isnt backwards, I never took it off. Are there any other things that could be causing this?
Old Apr 21, 2011 | 07:19 PM
Rickman48's Avatar
Are you sure the converter is seated in the pump??
Are you having to move it up to align the 3 bolt holes?
Try to turn the converter while unbolted, and see if there's any firm resistance - if not, keep going until you feel it engage the prongs on the pump. [it'll move back another 1/2 inch or so]
You may have to side the trans back, as far as the driveshaft will allow, to insure engagement.
I just hope this is your problem, and the pump isn't going away!!
Old Apr 21, 2011 | 07:26 PM
Well, I took the three bolts off and pushed it back as far as it would go, it seemed seated then. A little bit of resistance. And yes, I have to move the converter forward a lot to get the bolts to tighten down fully. I think when that when I do that it makes the converter disengage. I think Im just going to try and shim it with two washers in between the flexplate and converter so it doesnt have to come up so far. Hopefully I havent done any serious damage.
Old Apr 21, 2011 | 08:58 PM
76oldswarrior's Avatar
Is your converter and flexplate stock. I had problems with aftermarket converter mounts hitting the flexplate weight. Had to grind a little off the converter mounts. Sometimes you cant see it if the weight is up top. What you describe just reminded of that.
Old Apr 21, 2011 | 10:01 PM
64Rocket's Avatar
You still haven't said that you check the fluid level and that it was full when in park and warm?
Gene
Old Apr 22, 2011 | 04:50 AM
Yes fluid level is good.
Old Apr 22, 2011 | 05:43 AM
sb-stroker's Avatar
It is normal for the converter to slide forward about 1/4" when attaching to the flexplate. Not the problem, but it will be if you take all that clearance away with shims.
Old Apr 22, 2011 | 06:56 AM
Well, what else could be wrong? I have never had any problems with the transmission before.
Old Apr 22, 2011 | 07:43 AM
sb-stroker's Avatar
Have you tried all the gears, forward and backward, maybe the linkage is hooked up wrong. See if you can find a pattern to the failure. If it worked fine prior to removing the engine and trans it should work now if nothing was changed.
chasman414
Jun 25, 2020 07:05 AM
gregc
Sep 12, 2010 07:43 PM
ThyPlumber
Apr 27, 2009 12:55 AM
