Electronic distributor with 1970 Ram Air set up
Old Jun 11, 2022 | 12:53 PM
70 w-30's Avatar
Old Olds Fanatic
I’m using a factory delco-remy electronic distributor on a 70 350. It’s going into a ram air car. The distributor doesn’t clear the air cleaner as the old points set up did. It’s wider and the cap is taller. Any suggestions for an electronic distributor that has the same footprint as the factory one?
Old Jun 11, 2022 | 02:36 PM
Any points conversion system that goes in the original distributor. Also any aftermarket small body electronic distributor. Or, just keep the points, which will be more reliable than any of those aftermarket systems.
Old Jun 11, 2022 | 03:38 PM
Rallye469's Avatar
What about an MSD?
No coil on the cap…I believe you can find black caps.
https://www.summitracing.com/parts/msd-8529
Old Jun 11, 2022 | 05:06 PM
70sgeek's Avatar
'72 Cutlass ragtop
MSD 8529 ready to run is a small cap 3-wire electronic distributor which is same as OEM physical design. Pricey but essentially simple to set and forget.
Old Jun 11, 2022 | 05:13 PM
VC455's Avatar
Barely Registered
Originally Posted by 70 w-30
... It’s going into a ram air car.
Not to the point of your question, but in the realm of need-to-know:
  • You have a taller-than-factory intake and a carb spacer. This stackup will probably be too tall to fit a W-25 air cleaner adapter between the air cleaner housing and the hood.
  • As well, you appear to have a non-restricted heater hose adapter. If so, your heater core life will be short and leaky.
Old Jun 11, 2022 | 05:19 PM
andrewk94's Avatar
You can add a spacer to have the air cleaner sit above the distributor which is what I did in my 72. Used a Delco Remy 1975 distributor in my car. Worked well.
Old Jun 11, 2022 | 05:25 PM
Good observation. It took me three heater core replacements to learn this.
Old Jun 11, 2022 | 05:54 PM
70 w-30's Avatar
Old Olds Fanatic
Thanks, I’ll be changing the heater hose fittings after I install it. The observation about the W-25 system I’ve already been looking at. I’ll probably change the intake and carb after it runs. Thanks for everyone’s advice!
Ben
Old Jun 12, 2022 | 06:29 AM
Actually, the lower height of the SBO probably allows enough room even with that combo. Just use the shorter BBO foam on the air cleaner adapter.
Old Jun 12, 2022 | 07:04 AM
70 w-30's Avatar
Old Olds Fanatic
Joe,
thanks for the advice. I was going to install the engine and go from there. It’s really nice to have all this information and experience available!
I just measured the distance between the top of the valve covers and top of the carburetor where the air cleaner sits on an original w-30 455. It’s 3 1/2“, on the 350 it’s 3 3/8”. Pretty close to even. I’ll see how it fits in.
Ben
Orlando 1
Aug 31, 2020 07:37 PM
wr1970
May 7, 2017 04:10 PM
19cutlass71supreme
Feb 10, 2014 08:07 PM
B-Mann
Jan 18, 2013 07:04 PM
rcrac3r
May 10, 2012 09:34 PM
