Electric Water Pump Questions
I'm considering trying either a CSR or Meziere electric water pump. How do to still drive the alternator? My alt is mounted on the passenger side cylinder head, do you simply run a belt from the crank pulley to the alt? Would it need a tensioner of some kind since the belt is no longer wrapped around the water pump pulley? Anybody have some pictures they can post of their Olds electric water pumps and how you made it all work? At least I don't have A/C and power steering to add to the mix.
By the way, go to a real parts store, not Advance or Auto Zone, otherwise the teenager behind the counter will tell you the computer can't look up belts by length...
Thanks Joe, I know what you mean about "belts by length" at Advance and Autozone. If you can't give them an actual in the computer application, they are lost. I use Summit Racing, they have the belts listed by length.
free energy for all of us.
Just need to tap off that excess so it doesn't keep building speed ad infinitum.
Thank God they didn't connect shaft to shaft- the belt losses help keep the excess down, and serves as a fuse in case too much power is generated.
heh
I gave up on that MC forum not long after that...
I understand there is an ideal speed for a water pump to operate at its most efficient, clearly an electric pump can achieve this, a belt driven pump will almost all the time not do this.
It may be we will see electrically driven pumps in future engines, two advantages occur to me;
#1, The pump will probably use less power because it will not need to circulate adequately at low engine speeds or need restricting at high speeds.
#2, Engine temperatures will be easier to manage, for greater efficiency and possibly cleaner emissions.
The benefits will need to outweigh the costs, however the economies of scale will come into effect if this becomes the norm.
Roger.
How much power is used creating the extra 5 amps to drive the pump?. How much power is needed to run a belt driven pump?.
Roger.
Roger.
one driven by an electric motor can be questioned and that it could simply be an even trade-off in terms of
horsepower consumption from the engine.
Since the intent of the original post seems to be physically accomplishing the conversion,
my question is whether the existing alternator has the capacity to supply the additional current
required by the electric motor driven water pump.
Of course this will depend on how close the total existing loads are to the maximum current
the existing alternate can provide.
The ability of the engine to provide the horse needed to drive the alternator is not an issue.
Roger.
Nor Cal Andy
Mar 29, 2012 07:27 PM
