Egregious EGR
Old Mar 6, 2010 | 10:04 PM
henryk8398's Avatar
Hangin' out...
Egregious EGR
I've been experiencing a bucking/hesitation off idle and at cruise. To make a long story short, I have the EGR valve capped off right now and that makes the issues go away, so I know I'm going in the right direction.
My question is, why is the EGR getting repeated signals to open to the point of affecting drivability?
Old Mar 6, 2010 | 10:40 PM
Mike77's Avatar
Vacuum leak?
Old Mar 6, 2010 | 11:20 PM
henryk8398's Avatar
Hangin' out...
Originally Posted by Mike 77
Vacuum leak?
Possibly, but I've replaced every vacuum line I could find. At some point, the EGR was replaced, too.
Old Mar 7, 2010 | 06:49 PM
I have to give you points for what may be the first use of "egregious" in this forum!
Bonus points for alliteration, also.
Old Mar 7, 2010 | 09:58 PM
henryk8398's Avatar
Hangin' out...
Haha, thanks. That's what you get when I'm up late goofing off in the "man cave". I guess what I'm trying to understand is how this unit works. There are definitely some other symptoms that would suggest a vacuum leak. It's running very well, but that doesn't mean something isn't going on. Any tips on how to track them down on an SBO? Any common areas for leaks? Any failure-prone emissions components. Reading the troubleshooting section in the CSM only provided some vague idea that I might have a vacuum leak. Could a failing ported vacuum switch cause leaks? Any ideas would be appreciated. Thanks!
Old Mar 8, 2010 | 06:24 AM
There are positive and negative pressure EGR valves. Check to be sure the replacement is the correct one.
Old Mar 8, 2010 | 10:20 AM
henryk8398's Avatar
Hangin' out...
I'm going to have to look again and take a picture, but I think the replacement valve may be a generic replacement with an OEM# hand-written on it.
The plot thickens...
Mike77
Apr 30, 2024 05:54 AM
joe_padavano
Jul 1, 2013 12:03 PM
SX455
Sep 16, 2007 06:09 PM
81cutlassconvertable
May 26, 2007 05:16 PM
DonFrost
Ninety-Eight
Jun 22, 2006 04:16 PM
