Edelbrock Intake Manifolds 2711 Questions
Does any one know if the Dick Miller Valley Tray DMR-5580 or the Mondello Valley Tray VT-581 will fit under an Edelbrock Performer Intake Manifolds 2711? I know they won't fit under the Edelbrock Performer Intake Manifolds 3711. Also does a 1969 Olds 350 block have the holes already tapped from the factory for the trays or will I need to tap the block?
Thanks,
Noel
Thanks,
Noel
Thanks,
Noel
Thanks,
Noel
Thanks for your comment Mark. I was thinking of using either Motor City or Mondello heat riser block off plates along with a fiber gasket. Would that work, what would you suggest? Or should I just stay with the turkey tray?
Thanks,
Noel
Thanks,
Noel
They have to be totally sealed to be effective.
Bottom line is you do not need a valley tray so keep your money and spend it on things that you actually need.
I ran the DMR tray. Actually had his master template (he shipped it accidentally and asked for it back!). Fit just fine. You might have to use washers or something to raise it above the lifters. You can't bolt it straight to the block. I actually welded some stud receivers for wood onto the block.
Agreed that the crossover has to be blocked.
Bernhard
November 12th, 2012 07:05 AM
