Edelbrock Intake Manifold?
Old Nov 22, 2016 | 01:44 PM
Sweet64's Avatar
Could anyone let me know if the Edelbrock Performer RPM Intake Manifold will bolt on to a 1964 Olds 330 without any problems, i run a non ac/330 with power steering and brakes, stock 4 barrel intake manifold with a manual choke 600 eddy carb and cleaner, understand the Edelbrock RPM is almost 2 inches taller i believe,#7111 intake, is there any issues i should be aware of? Im shooting for more performance over the mid to high rpm range, found a good deal, Thanks everyone
Old Nov 22, 2016 | 06:31 PM
edzolz's Avatar
Should not be a problem since you have the manual choke. I have an older Edelbrock OL4B on my 330.
Old Nov 22, 2016 | 08:29 PM
Yes, it will bolt on without any issues. Will there be adequate hood clearance is another issue altogether and depends upon your carb and air cleaner choices.
Old Nov 23, 2016 | 12:24 AM
Sarum's Avatar
The Performer RPM will fit on a 330,I have one on my '65 Cutlass but you will not be able to use a 3" air filter.For a number of reasons you would be much better off using the Air Gap model.Edelbrock "fixed" the heat issue with this model something I am still trying to sort out with my car
Old Nov 23, 2016 | 09:11 AM
Cutlass Fan's Avatar
Does the performer manifold, by itself, give a noticeable increase in performance over the stock manifold in an otherwise stock engine?
Old Nov 23, 2016 | 10:22 AM
Sweet64's Avatar
Did Edelbrock ever come out with a Air-Gap intake manifold for the sbo/early 330's? Just curious everyone,and thanks for all your time and reply's, but what years do the accessories interchange with 330's to the 350's? Water pumps/heads/power steering pumps? Had me a little curious, sure seems like alot of stuff they sell for small block olds starts with 1965+, maybe its just a catolog error with some companies. Are the 1964 Cutlass small block owners still without options for headers? Thanks everyone.
Old Nov 23, 2016 | 11:01 AM
Kinda depends upon what you are starting with. On my '70 and '71 Cutlass 350s I didn't notice any performance difference.
Old Nov 23, 2016 | 06:19 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
There may be a small gain but hardly enough to notice with the regular Performer. The RPM will gain especially in the higher rpms, 2" of extra height help. At the same time on a stock engine with a tiny cam and weak valve springs, gains will be minimal. Pretty sure there are still next to no headers for the 64-67.
Old Nov 24, 2016 | 04:55 AM
cutlassefi's Avatar
They don't make an air gap style for a small block so that's a moot point. Sorry.
Old Nov 24, 2016 | 05:13 AM
If you mean vapor lock issues, look no further than your Edelbrock carb, yet another issue with them. The only time I ever got vapor lock with a Qjet was when I was hitting 230+ degrees with my 403.
Old Nov 24, 2016 | 07:38 PM
That's kinda what I expected. So a 1" or 2 " spacer on a stock manifold would probably help? Has anyone tried this?
Old Nov 24, 2016 | 09:07 PM
I thought both the 1" 4 hole and open helped on the regular Performer manifold. Put the thickest phenolic spacer you can fit, if you are having vapor lock issues.
jensenracing77
Feb 16, 2024 03:00 PM
pophop
May 13, 2011 09:57 PM
Topless72
Nov 20, 2008 08:13 PM
blue72regency
Oct 27, 2007 09:47 PM
