72 distirbuotr vacum control valve 350
Old Nov 21, 2016 | 06:42 PM
kennethlaw442's Avatar
wondering if anyone knows where i can get a dist vaccum control valve that mounts into the intake has 3 ports and a 2 prong electrical plug on top. 72 olds 442 with 350 in it. all the ones i see only have the 3 ports no plug
Old Nov 22, 2016 | 05:14 AM
That's a TCS valve.
Why do you want to install one of those?
If you're looking for one because you want to have a 100-point restoration, you'll have to find one used - post an ad in Parts Wanted.
Old Nov 22, 2016 | 06:05 AM
To elaborate on Eric's post, the TCS was an early emission control that disabled vacuum advance in all gears except high. The only reason to install it is if you want a totally correct resto. The car will run better if you leave it off and simply connect the vac advance to manifold vacuum.
Old Nov 23, 2016 | 05:35 AM
thks, yeah i was just putting it back to original , but think ill just leave it out.
Old Nov 24, 2016 | 10:44 PM
70sgeek's Avatar
'72 Cutlass ragtop
Parts Place has 'em NOS - translation: NOT CHEAP
http://www.ebay.com/itm/1971-72-Cutl...lXT15w&vxp=mtr
jensenracing77
Mar 19, 2014 04:08 PM
craftsman1956
Jul 12, 2010 08:33 PM
sshriber
Mar 22, 2010 06:16 PM
rocwal
Jan 30, 2010 10:29 AM
abram
Nov 7, 2009 11:46 AM
