Edelbrock cam....?
Old Sep 23, 2011 | 05:58 AM
Surftrip00's Avatar
Edelbrock cam....?
Had a suggestion of putting Edelbrocks 2151 Performer for BB Olds in the 350.....any feedback on this? Have the 350 cam in there now, was looking to up the ante a little bit and it was suggested that the Edelbrock 2151 cam would be good because (according to Edelbrock) designed to work well with the Performer/Performer RPM intake.
350 cam specs 280/290 duration .449/.473 lift
204 degrees/214 degrees at .050"
114 degrees LSA / Intake centerline 106 degrees
455 cam specs 288/298 duration .472/.496 lift
214 degrees/224 degrees at .050"
112 degrees LSA / Intake centerline 107 degrees
Any outlook on whether or not this would be a reasonable change or just look at something different. Power brakes...going to a 3.08/3.23 rear and have 1800 stall now (may need to step up)
Old Sep 23, 2011 | 01:12 PM
Surftrip00's Avatar
That would be cam part# 2152. Anybody?.....Anybody? Bueller?......Bueller?
Old Sep 23, 2011 | 02:26 PM
captjim's Avatar
What year 350 and is it stock? Depends on Cr, it will need mid 9.xx to work well, and you really don't have enough gear and converter. At 9 to 1, I switched from that cam to a 210/216 Engle with 3.08s and picked up .8.
Old Sep 23, 2011 | 02:42 PM
cutlassefi's Avatar
I'm with Jim on this one. You need 9.0:1 or better for that cam and gear. Better yet something on a bit tighter lobe sepand with a bit less stagger would give you better low end as well.
Headers? Intake? More info would be helpful too.
Old Sep 23, 2011 | 02:52 PM
Surftrip00's Avatar
Block is a 1969 with #5 heads rebuilt/machined....with 10.25:1 pistons in it. Trying get feedback on the intake too. Edelbrock of course recommends the Performer.....Ive had a few tell me step up to the Performer RPM. Def. going to change the gears in the rear end and headers for sure. Might be a little behind the curve on valvetrain combo's but I know it's gotta breath a li'l bit. :-) Looking forward to more info....Thanks!!
Old Sep 23, 2011 | 03:42 PM
captjim's Avatar
If you have 6 cc pistons with an after market gasket, Cr is probably 9.6-9.8 to 1, pretty good for a street car. A cam in the 220 @ .050 and .500 lift on a 110 or 108 would be about right. The old 20-22 (226/230) Engle would be good with a little gear.
Old Sep 23, 2011 | 03:52 PM
Surftrip00's Avatar
I see. Another thing that just came to mind....the car does have power brakes. Would I be ok or would a vacuum canister be in order? Ive also heard to not "over carb" the motor.
Old Sep 23, 2011 | 03:56 PM
MX442's Avatar
I'm not small block savvy, but had the 472/496 (2152) cam in my 400 and it was lazy. I think there are better profiles than the ebrock cams. You don't want your car to look like a summit catalog puked on it, do you?
Marketing propaganda. Talk to one of our Olds vendors. They won't sell you one of these cams.
Old Sep 23, 2011 | 04:05 PM
Surftrip00's Avatar
"........You don't want your car to look like a summit catalog puked on it, do you?"
Hahaha....not really! :-) Good to hear first hand about the 2152 cam. Certainly don't want to waste time with something that isn't going to do what I want. I see a lot of guys here lean toward the Engle cams. Seem to not quite have the duration but still making good power.
Old Sep 23, 2011 | 04:51 PM
MX442's Avatar
Engle cams grinds the JM profiles.... Can't go wrong. Nowadays, I'd go custom roller. Forget flat tappet and zddp.
76Supreme350
Feb 25, 2023 11:43 AM
mefirst72
Aug 20, 2021 11:30 PM
69CutlassAlex
Jul 30, 2013 08:18 AM
70Cutlass_408
Jun 24, 2011 07:55 AM
