Dual 330 Exhaust
There have never been true dual exhaust manifolds for any small block Olds from the factory, except those used on Toronados in the late 1970s. The Toro manifolds don't work in a RWD application as the outlets point the wrong way. Even the W-31s got the normal manifolds with the cap on the crossover port on the passenger side.
There are aftermarket manifolds available that have this port blanked off. I suggest you carefully compare them to stock and judge for yourself if they are worth the considerable cost. Contrary to some claims, these aftermarket manifolds do NOT have internal runners like the BBO W/Z manifolds. There just isn't enough room with the the SBO to do it.
2blu442
March 7th, 2014 06:09 PM
ah64pilot
May 29th, 2012 03:04 AM
65OldsDelta88SuperRocket
October 27th, 2011 09:16 PM
