Dropping Gas Tank - 70 Cutlass Supreme
Old Oct 13, 2014 | 10:16 AM
tgilligan's Avatar
Before I do something stupid, again....I wanted to ask first. What's a good way to siphon fuel from a tank that has the anti-siphon coil in the neck?
Lastly, as this is unfamiliar territory to me, I also want to replace the gas tank once it's empty, but how do I verify which type as OPGI, YearOne, etc have multiple types such as 1, 2, 3 vent, etc. It's a stock tank with a stock Olds 350 fuel pump that's never seen a replacment and it's due.
Apologies if this has been asked before, I did a quick search on the forum and found some similar postings but didn't find one addressing this specifically.
Old Oct 13, 2014 | 10:36 AM
70Post's Avatar
First thing.....check RockAuto.com for great pricing and great shipping rates. I think you will find their prices (and shipping charges) are A LOT BETTER than Year One and OPGI (which typically have the highest prices on repro parts compared to others).
If it's a non-California car then the Spectra Premium GM34Q is what you would use. The designation of "w/2 vents" in their description means there are the two separate metal vent pipes sticking out of the P side top corner of the tank....this is where the 2 hoses of your "surge tank" (the white plastic piece with the two hoses attached to it) attach.
Save yourself some good money and look at RockAuto.com.....
AND.....check in the "General Discussion" part of this site for the "Rock Auto Discount Code" thread. There will likely be a currently applicable discount code you can use with your order to save another 5% or so.
Old Oct 13, 2014 | 11:17 AM
tgilligan's Avatar
I default to RockAuto.com for most of my parts however for my 70' Supreme there are no options for a tank replacement which caused me to search on OPGI and YearOne's pages. Thanks for the explanation though.
Old Oct 13, 2014 | 11:37 AM
steverw's Avatar
Go back to Rockauto GM34Q look under 442. Its $124.79 I cant imagine it would be different for a CS than a 442. You can look under your car to be sure how many vents you have.
Old Oct 13, 2014 | 12:04 PM
It's not different. They use the same tank.
And to the question of how to empty the tank, I've gotten most of the gas out by disconnecting the rubber line that goes into the pump, directing it into a gas can, and using compressed air in the filler neck to force the gas out of the tank. I use a rag to seal the blow gun in the tank filler neck.
Old Oct 13, 2014 | 09:33 PM
70Post's Avatar
x3.....Rock Auto has some "bad" info on their site when it comes to tanks and Olds Abody Supremes or convertible Supremes. I spoke with them A LONG time ago about this and they claimed it had something to do with info they got from Spectra.
Regardless...they apparently haven't "fixed" their info...but as already mentioned the tanks are the same and it is made for your body style (as well as the others....same tank).
Old Oct 17, 2014 | 09:41 AM
HWYSTR455's Avatar
I have a new tank with a new GM sending unit/pickup you can have for free if you come get it. It's maybe 8 months old, I switched to an EFI tank. It's a Spectre GM34 with the fuel neck, ready to bolt in. Can post pics if you are skeptical. I'm in Northern VA, right outside of DC.
If you don't plan on using the old tank, just use a phillips head screw driver and punch a hole in the bottom, with a pan under it to catch it as it drains. Obviously, get it as low/empty as you can first. Can use a cheap electric, hand pump, or pressurize it as Joe P suggested. A garden hose and a wet rag works too, just blow in it.
Old Oct 17, 2014 | 10:14 AM
brown7373's Avatar
Buy 4 feet of 3/8 hose. Weight one end down (I attached a piece od dipstick tube) so it goes to the bottom of the tank. Cut a small slit about an inch or two from the other end. Stick a nozzle from your compressor in the slit, aimed toward the end and blow. The stream of air will get the fuel flowing without you drinking any of it.
Old Oct 17, 2014 | 11:11 AM
1970 does not have an anti siphon coil. What are you trying to describe? Is it the neck vent by any chance? I used the method described in the CSM which is the same as what Joe P posted. Works great. If you don't have compressed air, better have some clean water and mouthwash handy...gas in your mouth tastes bad and burns too.
Old Oct 17, 2014 | 11:58 AM
HWYSTR455's Avatar
You never suck when you syphon, you blow. If you put the hose in the tank, wrap a wet rag around the opening to make a seal, you blow, the tank pressurizes, and when you stop blowing, it comes out the hose. You can put your thumb on the hose and blow several times to build pressure. Drop the hose lower than the tank neck and into a can. It will start flowing and begin the syphon.
I know a lot of you guys lived during the odd/even days and some of the other gas crunches, you had to have syphoned gas before!
Old Oct 17, 2014 | 12:07 PM
Naw....really?? My 73 Custom Cruiser thought gas was free. So did my 78 Caddy. You can't imagine how horrifying it was to see gas at 42¢/gallon back then!
Old Feb 12, 2018 | 03:20 PM
Toms cutlass's Avatar
Old thread update: Rock Auto no longer offering Spectra fuel tanks for Cutlass/442.
Edit from info in posts below: Rock Auto does offer Spectra fuel tanks. Search under "Cutlass" (not Cutlass Supreme or 442).
Old Feb 12, 2018 | 03:40 PM
HWYSTR455's Avatar
Tanks, Inc has them, pretty much the same price Rock Auto had them for:
http://www.tanksinc.com/index.cfm/pa...cat/cat127.htm
Jeggs carries the GM Resto ones (Gold Star) for $115:
https://www.ebay.com/itm/Golden-Star...paJwFX&vxp=mtr
But I've never held the Gold Star ones in my hand, so not sure of the quality.
If you're close enough to the supplier, you can pick them up at their' location for $80:
https://www.ebay.com/itm/New-GM-Rest...xXwY76&vxp=mtr
Old Feb 12, 2018 | 04:05 PM
70-442-W30's Avatar
344879M363895
Ordered mine from Amazon but it is only 3rd party sellers on the listing now.
Amazon Amazon
Old Feb 12, 2018 | 04:06 PM
tgilligan's Avatar
RockAuto does still stock and sell the Spectra tanks but it’s indexed under the ‘Cutlass’ rather than the ‘Cutlass Supreme’. However as long as you find the right tank to match venting and any misc connections they should be interchangeable. I picked up my Spectra tank from RA under the base Cutlass for my Supreme and it was a direct fit.
Old Feb 12, 2018 | 06:13 PM
Thank you all for your replies.
I searched Rock Auto under both "Cutlass Supreme" and "442." I also searched Spectra part # GM34Q. Tgilligan, I stand corrected, RA does offer them under "Cutlass."
I found the Spectra GM34Q on Amazon as well as multiple sellers on eBay, one that offers it in stainless steel.
Thanks again.
Old Feb 13, 2018 | 02:32 AM
shiftbyear's Avatar
Just curious, has anyone noticed any inside corrosion or other internal problems due to using 10-15% ethanol gas? Would a stainless steel gas tank hold up better? I have heard of carburetors having problems but has anyone seen anything after taking their gas tank out?
Old Feb 13, 2018 | 03:35 AM
Inline's Avatar
I just dropped my tank. Pitting on the bottom of the tank ( inside). Pick-up tubes filter-sock was also deteriorating.
Tho, its 40+ years old.. Id just say given its age, its normal.
Like who knows if it has been sitting 2 years under tree, tank empty?
joemo
Sep 21, 2022 04:47 AM
pbob42
Apr 6, 2013 01:07 PM
1carsick
Oct 17, 2012 09:10 AM
Texas442
Jan 30, 2012 05:36 PM
Joffroi
Mar 21, 2011 05:15 PM
