Driver Side Alt Brackets
Old Aug 17, 2025 | 04:34 PM
Mr Nick's Avatar
I am currently using a non-AC passenger side alternator mount. I am considering adding Vintage Air A/C into the car so I'll need to move the alternator to the driver side.
Is this all I need to make the swap? eBay brackets
Is there anything different about the power steering bracket depending on driver or pass alternator mount location?
Thanks.
Old Aug 17, 2025 | 05:12 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
There are a couple of different alternator bracket setups, the later 260 and 307 use the aluminum top bracket. The early and later power steering reservoir are different. The later setup is tighter to the motor vs the early setup. It is good to have the dual pulley power steering, more belt routing choices. What length water pump and what pullies are you using?
Old Aug 17, 2025 | 05:31 PM
Mr Nick's Avatar
Engine is out for a rebuild, I think I'm using a short pump with factory "underdrive" pulleys. I know I'll need to find 3 groove pulleys and a new water pump as well.
Looks like this is another option. This is the style that is usually missing the rear bracket because nobody puts it back on after needing to remove a valve cover....
https://www.ebay.com/itm/166187932099
Old Aug 17, 2025 | 09:07 PM
442crzy's Avatar
I have those same brackets shown on that eBay link for $80 instead of $200 FYI
Old Aug 20, 2025 | 07:50 PM
Mr Nick's Avatar
Thanks, but I'm all set on the bracket via a different member here.
442crzy
Aug 26, 2023 07:11 AM
Skydog9
Jan 8, 2021 10:01 PM
Blue66
Jul 26, 2019 03:10 PM
74sprint
Jan 26, 2017 08:51 PM
jrmorte
Nov 24, 2009 07:17 PM
