Do I need to degree my camshaft?
Old July 23rd, 2021 | 01:53 PM
HarrySlother's Avatar
Im installing this cam into my 350 along with new roller tip rockers,springs and everything else. Timing chain is a comp double roller which I have read has been off when lined up on the two dots. Do I have to degree it or will it be fine if it is off. Or should I put it on the advanced slot which is 4 degrees I believe
Old July 23rd, 2021 | 02:23 PM
coppercutlass's Avatar
Chevy budget Olds powered
If you wanna not degree it buy a really nice timing chain and that's the best worst advice I can give. The last 4 cams I have degrees have all been off ( timing chain). Will it be fine ??? Maybe maybe not.
Old July 23rd, 2021 | 02:48 PM
Well I guess I'll be degreeing it then. My father would say just throw it in and then set the distributor timing by ear lol, but I'd rather do it the right way.
Old July 23rd, 2021 | 03:02 PM
The ignition timing has nothing to do with the camshaft "degreeing".
  • The ignition timing is when the spark occurs relative to the piston position.
  • The camshaft "degreeing" is when the valves open/close relative to the piston position.
Old July 23rd, 2021 | 03:57 PM
Yea I know. I was just giving you an example of the wonderful knowledge and wisdom I have access to at any time(sarcastic)
Old July 23rd, 2021 | 04:41 PM
cutlassefi's Avatar
I just degreed the cam on my latest SBO Stroker build. Comp Hyd roller, billet crank, Cloyes billet timing set. I had to retard it 6* to get the 3* advance I wanted. Degree it.
Old July 23rd, 2021 | 05:24 PM
Ah, I see.
Well, now you have this forum, which is probably the best source you could find for accurate information.
Old July 23rd, 2021 | 07:49 PM
Stefano's Avatar
Yes, you should always degree a cam. It doesn't take long to do and there is no guessing.
Dr. Oldsmobile
January 15th, 2019 03:47 PM
cwb442
January 27th, 2015 06:05 AM
scooter123
December 16th, 2013 01:20 AM
Stevec
October 14th, 2013 06:56 PM
oldzy
August 31st, 2011 06:02 AM
