Dip Stick Tube
Dip Stick Tube
Hello Everyone,
My dip stick tube snapped off where is goes into the block. It's a 67 Vista Cruiser 330. Does anyone have a good source of getting a stock one? Or does anyone have one they want to sell?
Thanks,
Jim
Thanks,
Jim
I noticed that Inline Tube sells a dip stick tube for 68-72 small blocks. Would this work in a 330?
https://www.inlinetube.com/products/inl13239
Thanks,
Jim
Thanks,
Jim
Tubes and sticks are matched pairs as sometimes there are different lengths depending upon the application. Chris Witt documented the matching tubes and sticks in this parts database.
Here's what I found in my copy of the database:
I just put the blue tipped one on from inline tube a few months ago as mine was snapped off in the block 2, it fits good on my 350 block.
Many of us have been here before! Use a slid hammer with something like a wood screw on the end. It will come right out.
Another option if your not super concerned about original appearance. Get a more common dip stick and tube for a 350 engine. Change the oil and be sure the filter is full, then once it settles pull the dip stick. Scribe the dipstick at that level. Functions just as well as the original reproduction.
Tubes are the same diameter. If you're concerned about original look, be sure to check the length of your new tube versus your old tube. If you put in the wrong length, your indicator will read high or low and you will not know it.
