Differences on a 1966 Cutlass non A/C and A/C water pump??
Old March 20th, 2011 | 01:57 PM
Nor Cal Andy's Avatar
Hi Im in the process of installing factory AC on my 66 Cutlass. I pulled everything except the water pump off the donor car.. I wanted to replace the water pump as Im also putting in a new motor. Is there a difference in the A/C and NON A/C water pump??? I found online two different part numbers. Is there a way to make the non A/C pump work?>????
Andy
Old March 20th, 2011 | 05:03 PM
2blu442's Avatar
Andy, the waterpump will have a longer shaft on the AC application. Your pullys won't line up if you have the wrong water pump on, and I suspect there's a reason for the different pump or Oldsmobile wouldn't have gone to the trouble. Do you still have the donor engine? If so, measure the length of the water pump from where it bolts to the timing cover to the ring where the pully attaches. If your purchasing the replacement pump local take the old one in and match it at the parts store. This has caused more than one headache and a second trip to the parts store for me and I'm sure others too! John
jeff70
May 20th, 2015 09:44 PM
jeff70
February 13th, 2015 10:16 AM
rktolds
October 23rd, 2014 08:20 PM
Nor Cal Andy
March 29th, 2012 08:27 PM
silverriff
June 9th, 2008 03:43 PM
