Vin Decoder
or
Login with Facebook
Damper bolt 215cid engine
January 24th, 2022, 07:12 AM
Swisspeter
Hello, is this bolt a standard right hand thread bolt and if so, what is the best way to undo it?
Thanks, Peter
Swisspeter
Find More Posts by Swisspeter
January 24th, 2022, 08:01 AM
joe_padavano
Yes, it's RH thread. An impact wrench is the easiest way. If you don't have one, you'll need to hold the flywheel with a flywheel turner tool.
joe_padavano
Find More Posts by joe_padavano
January 24th, 2022, 04:50 PM
BillK
The torque on it is 140-160 ft lbs so it will not be easy
BillK
Visit BillK's homepage!
Find More Posts by BillK
February 1st, 2022, 08:04 AM
Swisspeter
Hello Joe,
Thank you for the advice. I had to get a proper impact wrench and then it was easy.
Peter
Swisspeter
Broken bolt
Reese Neis
March 24th, 2021
02:38 PM
Swapping 68/72 12 bolt into a g body!?!?!
Kyle's77cutlass
Drivetrain/Differentials
15
February 24th, 2020
05:44 PM
Removing a stuck bolt
king_doodle
March 13th, 2018
08:52 PM
gm 12 bolt vs 8.5 10 bolt
dman0712
March 16th, 2010
07:40 PM
12 bolt vs. 9 inch Ford Rear end.
mcutlass1969
March 6th, 2008
10:24 AM
are remanufactured worth it?
Posting Quick Reply - Please Wait
Quick Reply:
The following errors occurred with your submission
Okay
Quote message in reply?
07:47 PM
