crankshaft pulley 350
Old May 7, 2010 | 10:28 AM
D Appeldorn's Avatar
know i'm confuced,
i thought that all the 350 used the same crankshaft puley's.
i got a 350 engine in my 69' delta 88 and want to replace my crankshaft puley.
saw it at fusick under cutlass section, but now it seems that it will not fit my delta 350?
where is the difference in it?
Crankshaft Pulley: Two groove pulley replaces GM # 405459. Fits 1970-77 all
V8s except A/C or H.D. cooling, and all 1972 W30 models.
CSP59 Crankshaft Pulley 1970-77 Cutlass/442
now i proberly have the HD cooling fan 6 blade 19a 20 inches?
no idea why, i don't have A/C on it.
are there many sort's of 2 groove pulley's used on the 350?
Old May 7, 2010 | 10:57 AM
svnt442's Avatar
There are 3 different length pulley sets because there are 3 different length water pumps. Thus the crank pulley needs to be matched with the water pump pulley. and the number of grooves will change as well. A 1, 2, or 3 groove depending on the options (there were even 4 groove pulleys on 307s, but that won't apply to you).
Old May 7, 2010 | 12:13 PM
As Randy noted, the crank pulleys aren't specific to the engine, they are specific to the installed options. If your car has A/C you need a three row crank pulley. If you do not have A/C (alternator is on the passenger side) you need a two row crank pulley. It doesn't matter if it's a 350 or 455.
Old May 7, 2010 | 09:51 PM
J-(Chicago)'s Avatar
Seasoned beater pilot.
Post the letter code on your crank pulley, and someone on here should have one. Is yours ruined?
Old May 8, 2010 | 09:14 AM
a shall surche for that letter.
got a 3 row on it, and a 19 inch 6 fan so it is possible that someone got my AC
mine is a bitt off, someone tried to get off the balancer.
got my a new one not original but a tuning part balancer, and the pulley swings a bit.
And do not want to wait till the cranck seal starts to drop
Old May 10, 2010 | 11:05 AM
should it be a full letter code? i saw only ( i think) a small letter S
it is re-spraid. could be a scratch
So where to look, before i bolt it off.
thanks
Old May 10, 2010 | 02:56 PM
There is usually an S, and then a 2 letter code opposite of it.
Old May 12, 2010 | 11:20 AM
if found some letters, difficult to read but maybe you guy's understand.
99405 KE? or something lik that.
http://img100.imageshack.us/img100/8220/12052010010.jpg
Old May 12, 2010 | 11:27 AM
joe, did anyone remove data on the tech side?
i have a hard time to find my 390327 intake manifold data again.
Had it written down but lost it.
Old May 12, 2010 | 12:58 PM
1968 Assembly Manual:
Crankshaft: KB 399402 2g 6.4 x 2.2" 0.901
Water pump: KE 399401 7.10 x 2.0
Power steering: KG 399403 1g 5.72 x 1.42
Alternator pulley - 1100767 AG
5.1" water pump snout
2nd groove: belt #399594; C-WP-PS
Old May 13, 2010 | 12:18 AM
now i get confused
can't vind such thing in my service manual.
but i have 3 rows on the crank, 3 on the fan puley, 2 on my steering,
and i do have my alternator on the left
and i can cut of a row if i want becouse the are not in use.
So, is the 2 row same as te first 2 orws of te 3 row?
same backspace?
if not i nead a 3 row again. or change everything
Old May 13, 2010 | 03:50 AM
Question #1: What is the water pump snout length?
5.1, 5.6 or 6.1?
Question #2: What is stamped on the water pump pulley? (need a clear answer here)
Question#3: what is stamped on your power steering pulley?
They are usually all stamped K something, so
not enough information yet.
399405 Should be a KC crank, not a KE or KB
Old May 15, 2010 | 11:07 AM
waterpump is stamped with LD? B9 with a small s under it
on the powersteering say's Front KH?
forgott to mesure the pumpsnout,
69' delta 88, 3 groove pulley, water is 3 groove and powersteering is 2 groove
Old May 15, 2010 | 11:58 AM
64Rocket's Avatar
from the pic he sent. It looks like he has a mis match pulleys from an A/C set up.
But the car does not have A/c. At some point the engine was changed or was in a crash and needed new pulley's and water pump.
So now need to measure the water pump and find the pulley's to match for a non A/C set up.
Gene
Old May 15, 2010 | 01:54 PM
Gene
Agreed. Or he can just run AC pulleys and an ac style alternator bracket on the driver's side.
1974
LA crank 3g
7.8 x 2.3 1.368
LD Water 3g 5.7 x 3.7"
KA 412628 Steering 2g 6.6 x 2.2"
6.1" water pump.
1968
"KC 399405
3g - 7.5 x 3.0" 1.230
Water=KF 399404 3g 6.10 x 2.70"
Steering= KH 399406 2g 6.6 x 1.95"
5.6" water pump
1968 NON AC
Crank=KB 399402
2g 6.4 x 2.2 0.901
Water="KE 399401
2g 7.10 x 2.0"
Steering= KG 399403 1g 5.72 x 1.42"
5.1" water pump
Old May 16, 2010 | 03:19 AM
waterpump was renewed, but i also have 2 holes in the firewall that could be used to get hoses inside.
i use it know to get my extra wire's in.
Old May 16, 2010 | 10:47 AM
how do i measure the snout, my waterpump pully measure 4cm (1,6 inch) against first row to end of snout.
must i measure the total snout? from sealing to end? ( til the black rotor where the pully bolts on?)
Old May 16, 2010 | 10:53 AM
Old May 16, 2010 | 12:57 PM
Old May 17, 2010 | 12:22 AM
64Rocket's Avatar
Why do you need to change the pulley? It looks like they are doing the job.
Is there a problem with the crank pulley?
Gene
Old May 18, 2010 | 11:38 AM
yes i have it, 6.1 inches. needed the converter for inches cm
15.5 cm ----> 6.1 inches
checked my 69 manual but see not the marking it should on a AC waterpump
Old May 18, 2010 | 11:42 AM
64 rocket,
the pulley wibbels, is a bit off. former owner tried to hammer the pulley and balancer off the crank.
so i allready had to buy a new balancer
and i'm scared that my crank seal is gonna leak trough this
there are 2 holes where i put my extra wires trough
Old May 24, 2010 | 09:21 AM
i think i have the KC 399405
Even when it is not correct to my waterpumppulley.
if you see if i put on a ac there are not aligning with the other pulley's.
my waterpump snout is to far back to use the first one.
And i do not know if i have to worry when te crank pulley is not blanced right.
Mocephus
Apr 12, 2015 06:39 PM
1950 Model Olds
Tech Editor's Desk
Jul 20, 2011 09:02 AM
hawks70
Jun 15, 2011 11:07 AM
rustycragars
Dec 3, 2009 10:46 AM
sssingo
Nov 9, 2008 03:47 PM
