coolant in my oil
coolant in my oil
pulled the plug on the oil pan today, and what did i see? chocolate milk looking oil.
now before i start replacing heads and gaskets, are there any common problems?
its a 1977 350 rocket with 3a heads.
lol i need to get this thing up and going before my wedding in april
Todays gasket manufacturing standards are quite high and they have better production standards that should minimize quality control issues of the past.
April??? You've got tons of time pal. After you put the new gaskets in, I would change the oil again fairly soon just to make sure all the contamination is out of the journals, and block passages. New oil is one of the cheapest forms of protection you can give a car in the long run. Why, your car could outlast your soon to be bride.
Good luck with your fix. Hope it works out well.
So, Import extermination. Do what you need to do to fixit. Do what you want for extras. Lots of the mechanical stuff you can do yourself or with a buddy.
"It's kind of like going to the store for bread and buying 200.00 worth of groceries that weren't on the list."
Either you shop at Costco, or like me were told many times over the years to do the job right the first time! Even if it takes a little longer or costs a bit more, you'll be ahead in the long run.
Originally Posted by oldsonharmont;185749 Either you shop at Costco, or like me were told many times over the years to [I
do the job right the first time![/I] Even if it takes a little longer or costs a bit more, you'll be ahead in the long run.
normal running temp was around 180. maybe once or twice it would reach 200 in the extreme heat at a traffic light. but i thought it was just the 1 core rad that the idiot before me put in( have a 4 core aluminum yet to be installed).
none of the idiot lights came on, no white smoke or sweet smell.
i ran across this problem while doing my routine oil change.
ps. allan r, i know i have lots of time till april, but im also in the process of quarters and a few other patches. lol the more i dig the more work i find... but i guess thats a project for ya lol
Either way it sounds like you get to start tearing into the motor somewhere. If the intake is aluminum, then it could be suspect. I'm currently doing the water pump job and have seen how bad those timing covers can corrode. It wouldn't take a lot for coolant to enter the motor there.
Good to know. I was thinking of going with an Edelbrock Performer kit (intake and cam) for my new 455. I'm really interested in finding out where your leak is now, and what caused it.
