Coolant leaking from under dash,,,,,suggestions please
Today I noticed a steady stream of coolant leaking from under the dash on the drivers side. Any ideas on where the coolant could be leaking from. I have attached pictures of the leaking. This is for a 70 Cutlass Supreme 350 w/AC.
Thanks,
Thanks,
More than likely heater core is rusted out and causing the leak.
Fast fix, remove heater hoses from water pump and at the firewall in the engine compartment and cut one hose in half and use one of those pieces of hose to connect to the out put nipple on the water pump and connect the other end of the hose to the input nipple on the water pump and make sure the hose doesn't kink off flow.
Or you could just go to your local parts store and buy those little hose block off caps but they are only good for about a year.
The fast fix method is best when this happens to you out on the road somewhere and there are no part stores open or in sight. This is always a good reason to carry an empty washer fluid bottle along with ya at all times in the trunk.
So let me see if I understand this properly since im not that savy wrenching on cars. So im disconnecting the heater core hoses at the firewall and relocating the heater hose thats connected to the water pump to ?? , have a look at the picture I just attached.
thanks again for the help.
Yes, just take either hose and follow that red line you drew in the second picture to connect it to whichever place it wasn't connected before.
You can leave the other hose connected to the heater core if you'd like - you can even connect it to the other heater core tube if you want to.
The tough part, of course, is replacing the bad heater core.
Keep in mind one hose is 5/8" and one is 3/4", so the fit will either be loose or tight, depending on which one you move. Also, avoid putting much stress on the heater valve at the back of the engine. If it is old, fatigued, or very rusty, it could break on ya.
Therefor, i would prefer to move the 5/8" one from the heater valve and connect it at the water pump. Remove the long 3/4" one completely. Use coolant to lube the inside of the hose and outside the connection of the water pump and you should be able to coax it on (providing it is long enough (I think it will be)).
I have mine bypassed right now cuz of a leak, I just run the hose coming from the waterpump right to the inlet on the back of the engine. I just completely removed the shorter hose that normally would go from the firewall to the inlet on the back of the engine. It's been like that since last summer:-). Of course, my car is a summer toy, not a daily driver. So I don't need heat....
Just because it was time.
Do you mean that water is coming out through the vacuum line (and going through the A/C controls and into the engine)?
Or do you mean that the vacuum line won't hold vacuum anymore?
Either way, time for a new valve.
Theres coolant leaking out of the vacuum hose, and leaks on to the intake and down to the floor.
So I replaced the heater control valve and I noticed that the vacuum hose on the back of the valve has a tear in it and needs replacing. Any one know where i can find a replacement.
thanks
thanks
Thats because it was stretched over the nipple for so long. If the new valve has the same size nipple as the old valve, cut the hose a little shorter, dab a little water (or hairspray) on the nipple (to act as a lubricant), and shove it on! Hairspray will allow it to slide on easier and will help glue it in place also.
To prolong the life of your heater core, it is a simple modification to install manual valves on the heater hoses so that during the summer months, you can manually turn off water flow to the heater core. Then replace the heater valve on the manifold with a simple nipple and viola! When winter hits, you open the valves & turn on the heater...
This is of couse what you do AFTER you replace the heater core
![Wink](https://classicoldsmobile.com/forums/images/smilies/wink.gif)
I just spit on it, and it works fine.
My wife would KILL me if she caught me with her hair spray working on the car!
Unless, of course, you mean you've got your OWN hair spray...
![Big Grin](https://classicoldsmobile.com/forums/images/smilies/biggrin.gif)
cgjon
June 26th, 2006 06:19 PM
