carb spacer...
Old Jan 19, 2014 | 08:06 AM
Shaunbo13's Avatar
carb spacer...
Hey guys! Im putting in a 3711 intake with a 600 cfm carb all edelbrock. I need a 1.5 in spacer to clear the egr port. I can't seem to find them anywhere. Any suggestions? Can i put two spacers together? If i put a 2" on will it clear the hood with an aftermarket air cleaner? Kinda stuck. If i can find a place that sells the spacer i need that would be awesome, but where?
Old Jan 19, 2014 | 08:46 AM
cutlassefi's Avatar
Try Summit, they're all over the place. 1.5" should clear everything just fine but you might need a drop base for your air cleaner.
Old Jan 19, 2014 | 10:06 AM
J-(Chicago)'s Avatar
Seasoned beater pilot.
I have an extra 2" here if you have the space for it.
The others I had laying around were 3/4, or 7/8". Sorry bud.
Old Jan 19, 2014 | 11:29 AM
Shaunbo13's Avatar
I tried summit they do not have an 1 and a half, but can i use a 2"? Will it still work if i drop the base of the air cleaner?
Old Jan 19, 2014 | 03:03 PM
If you bought the 2711 instead of the 3711 it wouldn't have the egr boss on it. your 68 shouldn't have had that problem.
Here's a link to a 1.5" spacer on summit. If you think you can get away with the 2" , just shoot me a pm.
http://www.summitracing.com/parts/csi-000030c/overview/
Old Jan 22, 2014 | 03:08 PM
Shaunbo13's Avatar
I didnt buy the 2711 bc the 3711 saved me a couple hundred dollars. It was in good shape, so why not. Besides a spacer gives it more air, right? I went ahead and bought a 2" kit studs, spacer, and gaskets for like 20 bucks..thx guys!
bdub217
Aug 28, 2012 04:46 PM
62radarlove
Feb 26, 2012 12:25 PM
defiant1
Sep 19, 2010 06:44 PM
deadmanscurve
Mar 12, 2009 06:42 PM
65Delta88
Mar 25, 2008 07:18 AM
