Carb questions
Old Feb 7, 2007 | 02:36 PM
American Lead's Avatar
2Blue 55
Question Carb questions
Hi, i just finished rebuilding my carb, but it is still hard to start, and still a tiny bit sluggish (bogging) from takeoff, anybody have any ideas on what is wrong?, thanks, robert howie
Old Feb 22, 2007 | 12:00 PM
gerlof_1's Avatar
did you check everything from the ignition too(points,condesator,cap,wires,plugs,etc)
Old Feb 22, 2007 | 12:45 PM
2Blue 55
Yes, I replaced all those but i was wobdering if it could be my vaccume advance Any more ideas,
Thanks for the reply
Old Feb 22, 2007 | 01:00 PM
gerlof_1's Avatar
if you did put all the vacuum hoses at the right place,and sure nothing is leaking try sucking on the vacuum advance hose
when its working properly you must see some small movement on the vacuum advance
is the compression ok?
Old Feb 23, 2007 | 04:26 AM
Oldsguy's Avatar
Past Administrator
Robert, make sure you have a good tight seal on the baseplate. Any air leaks into the manifold from any source other than the top of the carb is going to adversely effect the air fuel ratio and the carb's operation. Even a vacumm leak someplace else on the manifold. What is your manifold vacumm at idle?
Old Feb 28, 2007 | 02:31 PM
2Blue 55
thanks for all pf the replys guys, when spring comes I am going to take her for a good run and go from there, I am going to buy a vaccum meter and check vacume. I am also going to check compression and I will get back to you.
Thanks for all the help.
Old Mar 11, 2007 | 06:32 PM
2Blue 55
Thnks for all of the info, I tried all of the things you suggested, and everything was OK, i started it and let it warm up and now it runs just like a song, whatever the problem was, it is gone now, thanks oldsguy and Gerlof_1, I cant wait until the road dries off this week and I can let her stretch her legs.
Thanks again.
427king
Mar 26, 2011 08:56 PM
car_designer
Jul 18, 2010 04:55 AM
bocoogto
Jul 26, 2008 07:47 PM
bocoogto
May 20, 2008 12:30 PM
bocoogto
Mar 27, 2008 05:49 PM
