carb question
Old Jan 29, 2012 | 05:09 PM
mdfedewa's Avatar
carb question
iv got a built 350 with ebelbrock heads and intake. its around 400 hp with a edelbrock 750 carb. i want to put a holley on it, will a 650 with vaccuum sec. do the job?
Old Jan 29, 2012 | 05:35 PM
coppercutlass's Avatar
Chevy budget Olds powered
I have a 350 olds in the 400 hp range with a 600 cfm carb if fed it good. I did run a proform 650 double pumper it was just a tad bit big even after a lot of tunning almost had it perfect but my converter was to blame, too tight so the car bogged slightly. I could have changed the pump cams but i gave up . I ran a 750 edelbrock and that was just wayyyyyy to big didn't even bother to try to make it work sold it . My car ran great on the street and strip with the 600. i think a 650 vac. secondaries would work good. Alot would also agree a 750 vac. seconaries will work but those usually will require some re jetting and tunning. If i may ask why the swap from the 750 to 650 ?
Old Jan 29, 2012 | 05:46 PM
mdfedewa's Avatar
I'm not a fan of the edelbrock carb. My buddy had a 750 edel and went to a 650 Holley and had alot more power and better luck
Old Jan 29, 2012 | 05:56 PM
Yep i had the same thing. The 650 vac secondaries should work good. The 650 double pumper will work but it will need a looser converter and some tuning for the street from my personal experience. I used the 600 edelbrock out the box car went 13.3 straight out of the box. This year im running a bigger stall and 650 double pumper and see if there is a considerable change in e.t. and mph. I dont know if holley makes a 650 vacuum secondaries i know they got the 670 street avengers. Btw if you want a cheap holley straigh from holley go to ebay and go to holley's ebay store you can pick you price and find out in seconds if they accept it most are factory refurbished imo better than new . I picked up a remaned 650 dp for 250 straight from holleys kentucky plant.
Don R
Oct 6, 2012 09:47 AM
RandyS
Oct 4, 2012 12:36 PM
george88
Jul 29, 2006 11:20 AM
mjregim
Jul 24, 2006 12:43 PM
