Camshaft info
Old Aug 29, 2025 | 11:05 AM
Roger60's Avatar
Camshaft info
Back in 2016, I bought a new camshaft from Supercars Unlimited. I know they are no longer in business.
The part number on the receipt is 14-230.
My question is this: Is this a stock replacement (330 hi comp) or a mild upgrade? I can't remember.
Old Aug 29, 2025 | 02:52 PM
Did you not get a cam card or other paperwork with it?
Old Nov 16, 2025 | 07:39 AM
DanM's Avatar
Awesome User
Using archive.org to go back to 2016, I'm only able to pull up that its a factory duplicate camshaft:
330 67 4 bbl. AT. Camshaft
39 degree. OE #396192.
https://web.archive.org/web/20160527...afts-i117.aspx
You should probably be able to find specs on the that OE part number
Old Nov 16, 2025 | 08:08 AM
Factory specs for 396192 are 278/282 duration, 0230/0.232 lift, and 47 deg duration. This cam was also used in the 1967 400 4bbl motors with AT. Of course those duration numbers are the factory advertising numbers at "first motion".
rcdynamic88
Jul 18, 2013 05:01 AM
pontiac1
Feb 11, 2012 06:30 PM
jrblanke
Aug 7, 2011 08:19 AM
66olds4dr
Jun 21, 2011 10:47 AM
330noob
Nov 4, 2010 07:50 PM
