Camshaft end plug
Old Feb 27, 2011 | 07:53 PM
defiant1's Avatar
Question Camshaft end plug
I am going to be replacing my cam bearings in the next couple of days. I got the installer/remover tool already. Does the camshaft end plug have to come out? I assume it does to get at the #5 bearing, if so, do I use the removal tool to persuade it out or some other method? The CSM was not very detailed concerning this.
If the end plug comes out, do I need to replace it? I am not seeing any part listings for it. I figured I would have to reuse it.
d1
Old Feb 27, 2011 | 08:05 PM
Run to Rund's Avatar
It would be hard to pull the bearing and leave the plug. Dorman makes the correct soft plug.
Old Feb 28, 2011 | 07:00 AM
Dorman P49C
Old Feb 28, 2011 | 07:09 AM
defiant1's Avatar
Originally Posted by Run to Rund
Dorman P49C
Thanks, where did source that part number from?
This Dorman website (link below) has what it looks like 5 of the same thing:
http://www.dormanproducts.com/applic...EXPANSION+PLUG
d1
Old Feb 28, 2011 | 10:57 AM
555-049
I got the P49C from the stamping on a cup plug I bought some years ago.
Old Feb 28, 2011 | 04:13 PM
defiant1's Avatar
Got it, thanks. Say, I read where you are suppose to use non-hardening sealant on these plugs as well as the front oil seal. What would be an example of this? What do you all use?
d1
Old Feb 28, 2011 | 05:56 PM
cutlassefi's Avatar
Permatex Aviation with the brush applicator.
Old Feb 28, 2011 | 06:21 PM
defiant1's Avatar
Yes, I have heard to use that as well as High Tack.
Old Feb 28, 2011 | 07:36 PM
I use ultra gray or black RTV, extra on the outside so it can't come loose.
350TurBRO
Sep 12, 2014 11:52 AM
ds00469
Jan 25, 2014 05:12 PM
Robert Kiedrowski
Jan 25, 2011 04:31 PM
delkron97
May 15, 2006 08:12 AM
