Cam washer?
Old Apr 13, 2017 | 09:14 AM
330jetstar's Avatar
Cam washer?
I installed the new cam and timing set in my 330 last night after remachining of the block . The bolt head that holds the cam in seems small for the size of the cam gear. Is there supposed to be a washer. I know it's not a big deal I can just a washer. Wondering if I am missing a factory component.
Old Apr 13, 2017 | 11:21 AM
The bolt holds the fuel pump eccentric on the camshaft. No need for any additional washers.
https://classicoldsmobile.com/forums...iming-set.html
Old Apr 13, 2017 | 11:34 AM
jensenracing77's Avatar
You need to put a strait edge across the front rails of the block and measure how much clearance there is between the bolt and the front cover. If you go to much the bolt will hit the front cover. Don't forget that there is a gasket thickness between the cover and block
Old Apr 13, 2017 | 12:03 PM
330jetstar's Avatar
D'oh I feel like a dummy yes that's all it would be is the fuel pump eccentric. Oh boy.
Old Apr 13, 2017 | 07:37 PM
Cutlass Fan's Avatar
Good thing you asked your question. It would have sucked to get it all assembled and find out you forgot the eccentric.
joesw31
Jan 16, 2017 08:01 AM
grmchne78
Jun 25, 2015 06:23 PM
Oldsmaniac
Jun 20, 2014 05:44 AM
Uncle Hulka
Mar 12, 2014 03:41 PM
57teebyrd
Dec 21, 2006 07:07 AM
