Cam advice
Old March 17th, 2016, 11:03 AM
  #41
Mike Sundy's Avatar
Originally Posted by Mike Sundy
http://www.rockauto.com/catalog/moreinfo.php?pk=3638025&cc=1217449&jnid=434&jpid=0
This is the first one I found.
There is also this one.
http://rebuiltautoengines.com/oldsmobile-V8_5.7_350-old_350lb_4-engine.html
Mike Sundy is offline
Old March 17th, 2016, 11:07 AM
  #42
1BOSS83's Avatar
Here is my concern with that. I'd bet that motor has 24cc dish cast pistons, tiny cam and smog head. Maybe an 8:1 engine. 1,700 and you have to supply (or so it looks) valve covers, oil pan, intake, carb, distributor etc etc. so the 1,700 figure is sort of a misnomer. Additionally, I'd want to see some sort of build sheet to see exactly what it is- You don't want to spend 3k on a 170 hp engine.
I would try and get new heads. This site is full of guys who build heads and I was on another forum the other day and a fella was going on about how he will sell his #5 heads (cores) for something like $150.00 bucks. You have the desirable pistons and at this point new cam/lifters aren't going to be extremely expensive.
1BOSS83 is offline
Old March 17th, 2016, 11:14 AM
  #43
1BOSS83's Avatar
Speak of the devil..
https://classicoldsmobile.com/forums...50-250-mi.html
1BOSS83 is offline
Old March 17th, 2016, 11:48 AM
  #44
Out of Line, Everytime😉
olds 307 and 403's Avatar
I would pull the motor and check the bearings and crank, they might be near new condition. $1200 is Procomp territory and they won't flow as well.
olds 307 and 403 is online now
Old March 17th, 2016, 11:52 AM
  #45
Mike Sundy's Avatar
When someone says "core" does that mean stripped or just in need of some machining? If I bought some stripped ones, I'd be in the same situation I am in now.
Old March 17th, 2016, 12:13 PM
  #46
pherbicide's Avatar
My understanding of core means no valves, springs rockers and the like.
pherbicide is offline
Old March 17th, 2016, 03:13 PM
  #47
1BOSS83's Avatar
Core isn't necessarily a death sentence on the piece. My "core" 350 was a full running and driving long block with Proform HEI, performer RPM etc...If you have to redo heads it's better to look into a less grim option (you mentioned before you have damaged seats). if you find good solid cores and a machine shop is going to charge you 1,200 dollars to fit them with internals you should back away (don't turn your back on them) very slowly.
1BOSS83 is offline
Old March 17th, 2016, 03:58 PM
  #48
Mike Sundy's Avatar
I went to check out the cam and found this.
It looks like the eccentric has been welded on and I can't seem to get the nut off that is holding it all together. Any tips or is this thing FUBAR? Is getting heads worth it or should I just look for a whole new engine? There is a chance that everything inside there is still good but thats a hell of a gamble.
Old March 17th, 2016, 04:17 PM
  #49
Pull the engine to be safe, could be nice, could be a disaster inside. Why in the hell would someone weld that oil slinger on?
Old March 17th, 2016, 04:39 PM
  #50
TripDeuces's Avatar
It's not a nut but instead a bolt. If torqued correctly it's about 65 lb/ft so it will be a little tough to budge.
Once the bolt is out if need be you can chisel that eccentric off which will break the weld easily. Of course you might be looking at a new timing chain set and cam also. It's an aftermarket set and is loose anyway. You can see the slack in the chain.
TripDeuces is offline
Old March 17th, 2016, 04:55 PM
  #51
Mike Sundy's Avatar
I'm guessing it's over torqued because I used the same impact to take the crank bolt off. It pulled the crank bolt like it was in butter and didn't budge this one.
Old March 18th, 2016, 06:06 AM
  #52
1BOSS83's Avatar
Mike, what is your budget for this build?
1BOSS83 is offline
Old March 18th, 2016, 06:38 AM
  #53
Mike Sundy's Avatar
Around $2k knowing that it will go well beyond that.
Old March 18th, 2016, 07:32 AM
  #54
1BOSS83's Avatar
I would take the motor completely apart. Take the pistons , crank, block etc to your machinist and find out what you have. Exactly. If the foundation pieces are in good shape we can put together a build that will meet your budget and performance expectations. Just as an example, if those pistons are in good shape that's $400 back in the coffers right there. You MAW find out all the truths at once so we can best advise those critical questions and get some forward momentum. I paid my machinist $200.00 to take my motor completely apart and tell me everything I had and its condition (and it was running and driving) you don't know until you know. I'd honestly lose sleep if you bought 1,200 dollar heads only to find out the bearings are spun and the crank is not usable etc.
1BOSS83 is offline
Old March 18th, 2016, 05:11 PM
  #55
Mike Sundy's Avatar
Does anyone live in Ohio? This seems like a great deal if true. http://dayton.craigslist.org/pts/5484776936.html
fv64olds98
January 31st, 2013 02:56 PM
73supreme
July 25th, 2012 05:15 AM
Bugg
March 10th, 2012 02:14 PM
sphinx_57
January 23rd, 2010 06:40 PM
ijasond
May 13th, 2008 08:27 AM
Quick Reply: Cam advice
