A/C delete on my 307
Old Apr 15, 2013 | 04:40 PM
Black1984SNAPPING's Avatar
I wanna free up some space under the hood the air conditioning isnt a must for me as I like running windows down at about 60 MPH. So whats the pros and cons of doing this? And whats the proper way of doing so? I do have the haynes repair manual if any reference to that can be made. Thanks Dan.
Old Apr 15, 2013 | 05:32 PM
Redog's Avatar
Pro, less rotating on the motor, frees up HP
Con, other pullies are still there, bearing in the water pump will fail faster, not majorly faster
Old Apr 15, 2013 | 06:56 PM
captjim's Avatar
Not sure the difference in HP will be noticeable on a 307. Personally, on a stiock 307, the hassle and expense isn't worth the trouble, IMO. Delete plates are around $75, IIRC
Old Apr 15, 2013 | 08:00 PM
Rocket331's Avatar
Pro - can't think of any.
Con - you'll never sell the car to me.
Old Apr 16, 2013 | 02:30 AM
DoubleV's Avatar
Pros - Easier to work on engine somewhat. Less weight.
Cons - It looks stupid as $hit because you still have the whole AC module under the hood and the AC controls inside the car.
IMO, unless you swap to a complete factory non-AC setup, it's a hackjob and looks horrible.
Old Apr 16, 2013 | 05:45 AM
Pros: Appeals to some people's sense of being "cool" because it's "different."
It screams, "I did a big thing to my car."
Cons: As DoubleV said, "it's a hackjob and looks horrible."
It screams, "I did a big thing to my car!"
Isn't it less work to just slide the little lever to "Off"?
Old Apr 16, 2013 | 09:15 AM
The A/C compressor uses a clutch. With the A/C off, the HP loss on the engine isn't measurable. You will save about 50 lbs (out of what, 3500?). It does make the engine easier to work on.
Have you already deleted the A.I.R. system (or are you planning to)? If not, the A/C compressor serves as the adjustment for that belt, so you'll need an idler pulley instead.
Old Apr 16, 2013 | 03:09 PM
I haven't touched anything its all original nothing is off didn't want to do it for any other reason but to free up some space if it doesn't make that much of a difference I'll leave it be. I want the car as original as can be I guess I'm just jealous of all the guys who have nothing but a motor under the hood. As you all know the vacuum hoses ruin it for me already.
Old Apr 16, 2013 | 04:32 PM
DoubleV's Avatar
There are some tastefull eliminations you can do to make your engine much easier to work on and give you that cleaner look. Eliminating the AIR system for example. This alone does wonders and requires no butchery.
Old Apr 16, 2013 | 05:11 PM
captjim's Avatar
This is probably what you had in mind
http://s149.photobucket.com/user/cap...52711159655963
Old Apr 16, 2013 | 05:23 PM
Minus the gold paint haha but yes! I dont know much about this stuff so any bit of information or ideas from people that know the car is great! theres just a mess in there its horrible I'll have to post a pic this weekend when I have some time.
Old Apr 16, 2013 | 05:25 PM
Talking
I'm confused by what you mean "air system". How is this done exactly pics or tutorial links would be great. Seeing as how I dont know all the lingo for the vehicle.
Old Apr 16, 2013 | 06:42 PM
1BOSS83's Avatar
I'll tell you what, if you can keep some of those parts in tact I'll give you a few bucks for them. PM if interested in making a deal.
Adam, PA 83 Hurst/Olds
Old Apr 16, 2013 | 07:17 PM
DoubleV's Avatar
I have most of my AIR system if you're interested. Don't have the steel lines, but those are available aftermarket. Parts came off of my 85 442 at about 30k.
Old Apr 17, 2013 | 07:12 AM
1BOSS83's Avatar
I should have been more specific, I want the A/C compressor and condenser. The 83 Hurst was my first car and feeling like a 17 year old bad *** I yanked all the AIR and emissions equipment off the car (now ten years later I realize that was a dumb move). Be that as it may I need to figure out how to get this A/C working.
Old Apr 17, 2013 | 07:35 AM
ddd777's Avatar
Question
As my A/C is not operational, the person I am working with on my 72 with a 350 simply did not re-attach a belt to the compressor.
The thinking was that the bearings in the compressor would continue to take a beating for no reason. In the future I can loop back and fix the A/C (enough project this year).
Do I also need to do something with an idler pulley?
Old Apr 17, 2013 | 04:14 PM
M-14's Avatar
If you're keeping the heater get the 1st one, if not get the 2nd one.
carbonf00tprint
Nov 4, 2012 07:53 AM
DeltaDevil88
15
Jun 30, 2011 04:39 PM
J-(Chicago)
Jan 3, 2008 12:40 PM
59-59-59
Dec 6, 2007 03:17 PM
