Bypass Hose?
Bypass Hose?
hello:
I have a 1971 350 olds that has a hose that comes from the firewall to the manifold. I need to replace it can you tell me what its called and if its supplied at an auto parts store.
That's one of your heater hoses. There's one that runs from the waterpump to the firewall and another as you described. Just make sure you get the right inside diameter of the hose. If you have another car to drive you might remove the old one and take it in for them to match.
Be gentle removing it from the firewall nipple. Sometimes with old heater cores this can cause the heater core to leak. I like to use a razor blade to cut the side of the hose down the length of the nipple. Then you can use a flat bladed screwdriver to gently peel it back and off. When you install the new one put a light coating of grease on the inside of the hose. That will help it slide on easier and take less pressure.
John
John
Some applications require a formed heater hose; a generic piece will kink shut if used. If yours appears to be a formed hose, perhaps try www.fusick.com for the correct part.
squirell
September 22nd, 2013 02:17 PM
