buick to cadillac engine swap
Hey guys,
Been hangin out at this forum for a while, just came up on a question...maybe you guys can help.
I have a 1980 eldorado that came with an 368 bb cad engine. I want to put in an olds 350...which i have the engine.
I recently purchased a engine mounting bracket from an olds rivi (83-84). this mount was from an olds 307 equipped rivi.
the mount should be interchangeable to the eldorado since they share the same body style/frame. for some reason mine is not aligning up to my front crossmember. the angle is off.and since the 307 and 350 are the same block it should bolt directly.
the bracket is a one piece u-shaped bracket that bolts to the engine block and rests on the motor mounts.
the way the bracket mounts to the engine block it makes it sit at a different angle than the motor mounts are sitting. Any idea of whats wrong?
It is difficult to visualize your problem. Could you post pictures? The 307 and the 350 are both SBO engines. You shouldn't have any troubles swapping accessories from one to the other. Are you sure you identified the engines correctly?
pics pics pics!!!
SDC10886.jpgDSCN0009.jpgSDC10890.jpgSDC10888.jpgthese pics are not from my car...the pics of the bracket installed are from the original 83-84 rivi...the pics of the bracket itself is what was sent to me from the slavage yard....Joe does this bracket look like the olds small block bracket for 350 engine?
This picture looks exactly like the drawing in my 1982 CSM for a Toro, so it's consistent. The other bracket appears to be different with the mounting surfaces at a different angle, but it's hard to tell since the photo angles aren't quite the same as the one above. As I noted previously, the 79 Toro/Riv and 79-80 Eldo rubber motor mounts are listed as being different from the 80-85 Toro/Riv and 81-85 Eldo. Are you using the 83-84 Riv bracket with the Anchor 2629 mounts?
engine swap-joe
I am using the original motor mounts that came from the 1980 eldorado with the 368 motor. does this link show the correct mount
http://www.deaproducts.com/ItemsList.aspx
This is what my mount looks like...click on the image...it looks like the anchor 2629 i think, ill take a picture of it
Sanghi
June 2nd, 2015 03:48 PM
4rims
May 6th, 2013 09:55 AM
BeenThere
February 21st, 2013 10:42 AM
nbfalj
November 14th, 2012 12:33 PM
DeadBang1968
January 19th, 2011 06:35 AM
