Bolt question
Old Aug 29, 2016 | 03:23 PM
Mike Sundy's Avatar
Bolt question
One of my head bolts is streched but the others seem fine. Is this something that I can replace just one or should I do a whole head or both heads? The other head is already torqued down with a new gasket. Could this be a symptom of a bigger problem? There was a stuck valve and some bent rods on this side and they have all been replaced. The only things not replaced are the block, pistons, and crank. Thanks for the help!
Old Aug 29, 2016 | 03:56 PM
442Harv's Avatar
You can just replace the one bolt.
Old Aug 29, 2016 | 04:28 PM
X2
Old Aug 29, 2016 | 05:29 PM
Mike Sundy's Avatar
X2
Do they sell the correct strength at a hardware store?
Old Aug 29, 2016 | 05:37 PM
TripDeuces's Avatar
You'll need grade 8
Old Aug 29, 2016 | 07:29 PM
quaddriver's Avatar
4 Barrels of Laughs
From: I moved to pittsburgh so I can be near Primantis
I get chilly going to hardware stores for hardened head bolts....they wont be shouldered for starters....you cant get a set somewhere else?
Old Aug 29, 2016 | 07:39 PM
Mike Sundy's Avatar
I bit the bullet and bought a set of ARP from Summit. So much for the cheap route. Would switching one bolt at a time on the head thats already torqued keep the gasket intact?
Old Aug 29, 2016 | 07:54 PM
Charlie Jones's Avatar
Phantom Phixer
I think that you would be better off using half the set on the one side and leave the other side alone .
If this is an Olds 350 , O'Reilly's has OEM bolts for $2.49 . If you can return the ARP's .
http://www.oreillyauto.com/site/c/se...ake=Oldsmobile
Old Aug 30, 2016 | 01:17 AM
Mike Sundy's Avatar
Its already shipped so i'll probably go with the first option.
Old Aug 30, 2016 | 06:34 AM
It's your money.
tmcfall
May 29, 2024 12:41 PM
tru-blue 442
Drivetrain/Differentials
May 7, 2012 08:48 AM
72442conv
Mar 19, 2012 07:14 AM
olds4life
Oct 5, 2010 05:18 AM
dman0712
Mar 16, 2010 07:40 PM
