Belt sizes
Old Jul 29, 2012 | 08:21 PM
dingusboy's Avatar
Belt sizes
Can anyone tell me the belt sizes for a 65 cutlass 330 w/out ac. Need both power steering and alt.
Old Jul 29, 2012 | 09:37 PM
henryk8398's Avatar
Hangin' out...
Check out rockauto.com:
DAYCO Part # 15515 Accessory Drive Belt; Exceeds OE Specifications; Length: 51.50; Outside Circumference: 52.07; Top Width: 0.44; Angle: 36
Fan & Alt., w/o A.C.
DAYCO Part # 15595 Accessory Drive Belt; Exceeds OE Specifications; Length: 59.50; Outside Circumference: 60.07; Top Width: 0.44; Angle: 36
P.S., w/o A.C. (59 1/2 In. Belt)
Old Jul 30, 2012 | 05:40 AM
dingusboy's Avatar
Gotcha. Only question I have is that when I got he car, the power steering belt went around both the crank and fan pulley. The alternator belt only went around the fan pulley. The manual looks like the alternator should also go around the fan and crank pulley. If so, the alternator belt should be longer than the power steering belt. Any thoughts or photos?
Old Jul 30, 2012 | 11:34 AM
henryk8398's Avatar
Hangin' out...
I'm not sure what it supposed to look like. However, going off of the part numbers, it looks like the fan to alternator belt is significantly shorter than the power steering belt. To me, that means that it would run off the fan, not the crank. Fast forward to 1983, and the 307 is the same way.
Are there any distinguishable markings/numbers on your belts? If they are in tact, you can take them to an auto parts store and they should be able to measure them for you.
Old Jul 30, 2012 | 12:31 PM
dingusboy's Avatar
they are intact and I did get replacements. However, I just noticed that the alt. runs off of the fan and crank pulleys according to the manual. Seems strange that I can't get a part number for the double pulley alt. belt. It would seem to make sense because you can't get the belt in between the pulleys without removing the fan and pulley from the pump. It would make for terrible roadside repairs. Unless you have a secret to get the belt in between the pulleys.
Olds98
Aug 6, 2010 05:02 AM
geckonz08
Jul 25, 2008 12:44 PM
shaunr
Feb 20, 2007 06:42 PM
Want-A-Vert
Feb 3, 2007 11:23 AM
dynamic88
Oct 31, 2006 07:33 PM
