Because We Needed Another Thread on the Spectre CU165 Radiator
Old January 25th, 2017, 02:40 PM
jpc647's Avatar
Well I ended up deciding to try to use the 2 row aluminum radiator, and I found out that even these 2 row replacements are bigger than the factory 2 row.
So it wont fit in the saddles of the top plate.
I could probably remove the rubber inserts and use smaller ones. But I would have to do it top and bottom. Anyone else see something I'm missing?
Anyone else tried to use to 2 row replacement? If I'm going to have to modify the top plate and saddles, I might as well try and find myself one of the 4 row copper/brass units. At least it'll be durable!
jpc647 is offline
Old January 25th, 2017, 03:41 PM
The aluminum 2-row is sold as a replacement for the copper/brass 4-row, so, yes, it has the same dimensions as the 4-row.
MDchanic is offline
Old January 25th, 2017, 03:47 PM
'72 Cutlass ragtop
70sgeek's Avatar
here's an alternative - I have this in my '72 Cutlass and it drops right in
http://www.autocityclassic.com/cheve...inum-radiator/
Stamped and welded construction sets this apart from the rest. Radiator has transmission cooler. 1 1/2" inlet, 1 1/2" outlet. Original style ribbed tank.
This radiator is a direct replacement. It has dual 1 1/8" high flow tubes, 33% more capacity then 3-row 1/2".
Core size: 28 1/4" wide, 18 3/4" tall, 2 1/2" thick
Overall size (widest point): 33 1/2" wide, 18 3/4" tall, 3" thick
70sgeek is offline
Old January 25th, 2017, 03:58 PM
jpc647's Avatar
Why would anyone want a 2 row aluminum with plastic tanks over the 4 row soldered?
jpc647 is offline
Old January 25th, 2017, 03:59 PM
Because they provide the same cooling capacity, but the aluminum one is cheaper and lighter.
MDchanic is offline
Old January 25th, 2017, 04:29 PM
jpc647's Avatar
I suppose. The plastic tanks just worry me. :/
jpc647 is offline
Old January 25th, 2017, 04:43 PM
They're what's on every car made in the past 20 years, and seem to work on those.
Ask Eric (OldCutlass). He's been running one with his BB for the past few years.
MDchanic is offline
Old January 25th, 2017, 05:00 PM
jpc647's Avatar
I did talk to him.I thought the aluminum 2 row was a drop in radiator for a copper 2 row. His experience is why I chose to try it. I didn't realize the 2 row wasn't going to fit. If I'm going to have to modify everything, I just feel like it's probably worth having the copper and brass unit.
Anyone in the market for a new Spectra CU165 radiator!?
jpc647 is offline
Old January 25th, 2017, 05:17 PM
Out of Line, Everytime😉
olds 307 and 403's Avatar
I am with you on the plastic side tanks. They hold up for years but I had one split out of the blue. Radiators for our old junk is far from simple, either plastic/aluminum or all aluminum that tend to leak or are warped or don't fit right. I hope my recored 2 core is enough for the 350 in hot weather.
olds 307 and 403 is online now
Old January 25th, 2017, 05:44 PM
jpc647's Avatar
I'm going to talk to my local radiator shop again, but I literally need new side tanks and a new core, so they'd be custom building me a radiator. I think that's going to get pricey. :/
jpc647 is offline
Old January 25th, 2017, 06:51 PM
Is it that the saddles are in the wrong place or they just need to be opened a bit?
oldcutlass is offline
Old January 25th, 2017, 06:54 PM
IN the picture, it looks like it needs to be opened up:
MDchanic is offline
Old January 25th, 2017, 07:26 PM
jpc647's Avatar
I could probably just open them up, but I don't want to have it crack and break off if I try to slowly pry it open.
jpc647 is offline
Old January 25th, 2017, 07:33 PM
Old School Olds
tru-blue 442's Avatar
JPC. I also have a 2 row copper unit, PM me if interested, $50 + the ride.
I'm with you on the plastic tanks, they suck.. I have 2 behind the shop, both
have cracked tanks.
tru-blue 442 is online now
Old January 25th, 2017, 09:13 PM
It won't. Back in the 80s I bent mine open (well, it was mostly hammering) for a 4 row radiator I had borrowed from my brother in law's 68 GTO, then closed them back when I had my original 3 row end tanks fitted with a 4 row core.
Fun71 is offline
Old January 25th, 2017, 09:17 PM
... I don't want to have it crack and break off if I try to slowly pry it open.
It's really no big deal, and it's invisible.
Another alternative is to use a razor knife and cut a channel into the rubber, which will reduce the amount of bending needed.
MDchanic is offline
Old January 27th, 2017, 05:56 AM
jpc647's Avatar
Roughly what did that cost to have done?
I did a little bit of both. I'm going to use different rubber feet if I use the Aluminum radiator. Although one of the holes in the passenger side foot(where the rubber snaps into) was a bit rotted and broke off(no problem, I can epoxy the rubber back in place to hold it), but hammering and bending it out might not have been the best idea.
I have to swap it out again, because it leaks at the head under the cap. These friggen plastic tanks really are junk, aren't they!?
jpc647 is offline
Old January 27th, 2017, 11:07 AM
It's been a few years so I don't remember the exact amount but it was under $250.
I never had any issues with the replacement plastic/aluminum radiators on my newer cars. And the original one on my Jeep survived 14 years of brutal Arizona 110+ summer heat and serious off-road use before it started leaking.
Fun71 is offline
Old January 27th, 2017, 01:00 PM
jpc647's Avatar
Whoa. My local guy quoted me $429 to re-core it out to a 3 row radiator, re solder the outlets, etc. I just can't. I'll warranty the plastic one and give it a final go. Luckily it's winter time, and the car is just sitting anyway...
jpc647 is offline
Old January 27th, 2017, 01:02 PM
If you are really that unhappy with it, just send it back.
Old January 27th, 2017, 05:47 PM
The one in my old Jeep Grand Cherokee lasted 250,000 miles before the seam started to leak.
What's the longest you've heard of a brass radiator going?
​​​​​​​- Eric
MDchanic is offline
Old January 27th, 2017, 08:45 PM
jpc647's Avatar
But what would I get? The copper one is 1/2 thinner. so the rows are very narrow(part number spectra cu351). so it's either this, or one of the custom jobs like champion. At least these have a lifetime warranty through the parts store(which it seems like I'll be needing).
​​​​​​​- Eric
Interesting. The spectra one's aren't built too well though. I'll take some photo's tomorrow for reference.
jpc647 is offline
Old January 28th, 2017, 05:04 AM
Is it leaking at the overflow due to a bad cap or because it was overfilled and puking when hot? Is there a deformity in the seating area causing the cap not to seat?
Old January 28th, 2017, 07:43 AM
https://m.summitracing.com/parts/sum-380457#
If mine doesn't measure up, this will get the nod, very good reviews, one after a couple of years being used. I considered Griffin but there are too many that leak. In the defence of the plastic tanks, mine was 20 years old and had 350,000 km. They just look like *** in classic cars.
Old January 28th, 2017, 10:27 AM
jpc647's Avatar
Good suggestions. But it's actually that there is a small crack on the top of the tank.
Interesting. It's a bit expensive(I was really hoping to stay at or under $225ish, but I do like that it has a nipple for a water temperature sender and the good reviews. I may have to make my own craddles for it too, like the other reviewer did. Which honestly, at this point, wouldn't be the worst thing ever. Mine are a little rotted, and though I cleaned them up and the paint in drying, the next time around, should this radiator fail or leak, I'll replace the saddles too. I'll just break down and buy the repro ones(or make my own).
jpc647 is offline
coldwar
February 20th, 2014 01:09 AM
drjr56
November 12th, 2013 09:22 AM
navvet
September 25th, 2011 11:51 AM
ent72olds
May 9th, 2010 06:55 PM
citcapp
October 8th, 2009 02:00 PM
Quick Reply: Because We Needed Another Thread on the Spectre CU165 Radiator
