Because We Needed Another Thread on the Spectre CU165 Radiator
Old Jan 25, 2017 | 02:40 PM
jpc647's Avatar
Well I ended up deciding to try to use the 2 row aluminum radiator, and I found out that even these 2 row replacements are bigger than the factory 2 row.
So it wont fit in the saddles of the top plate.
I could probably remove the rubber inserts and use smaller ones. But I would have to do it top and bottom. Anyone else see something I'm missing?
Anyone else tried to use to 2 row replacement? If I'm going to have to modify the top plate and saddles, I might as well try and find myself one of the 4 row copper/brass units. At least it'll be durable!
Old Jan 25, 2017 | 03:41 PM
The aluminum 2-row is sold as a replacement for the copper/brass 4-row, so, yes, it has the same dimensions as the 4-row.
Old Jan 25, 2017 | 03:47 PM
70sgeek's Avatar
'72 Cutlass ragtop
here's an alternative - I have this in my '72 Cutlass and it drops right in
http://www.autocityclassic.com/cheve...inum-radiator/
Stamped and welded construction sets this apart from the rest. Radiator has transmission cooler. 1 1/2" inlet, 1 1/2" outlet. Original style ribbed tank.
This radiator is a direct replacement. It has dual 1 1/8" high flow tubes, 33% more capacity then 3-row 1/2".
Core size: 28 1/4" wide, 18 3/4" tall, 2 1/2" thick
Overall size (widest point): 33 1/2" wide, 18 3/4" tall, 3" thick
Old Jan 25, 2017 | 03:58 PM
jpc647's Avatar
Why would anyone want a 2 row aluminum with plastic tanks over the 4 row soldered?
Old Jan 25, 2017 | 03:59 PM
Because they provide the same cooling capacity, but the aluminum one is cheaper and lighter.
Old Jan 25, 2017 | 04:29 PM
jpc647's Avatar
I suppose. The plastic tanks just worry me. :/
Old Jan 25, 2017 | 04:43 PM
They're what's on every car made in the past 20 years, and seem to work on those.
Ask Eric (OldCutlass). He's been running one with his BB for the past few years.
Old Jan 25, 2017 | 05:00 PM
jpc647's Avatar
I did talk to him.I thought the aluminum 2 row was a drop in radiator for a copper 2 row. His experience is why I chose to try it. I didn't realize the 2 row wasn't going to fit. If I'm going to have to modify everything, I just feel like it's probably worth having the copper and brass unit.
Anyone in the market for a new Spectra CU165 radiator!?
Old Jan 25, 2017 | 05:17 PM
olds 307 and 403's Avatar
Out of Line, Everytime😉
I am with you on the plastic side tanks. They hold up for years but I had one split out of the blue. Radiators for our old junk is far from simple, either plastic/aluminum or all aluminum that tend to leak or are warped or don't fit right. I hope my recored 2 core is enough for the 350 in hot weather.
Old Jan 25, 2017 | 05:44 PM
jpc647's Avatar
I'm going to talk to my local radiator shop again, but I literally need new side tanks and a new core, so they'd be custom building me a radiator. I think that's going to get pricey. :/
Old Jan 25, 2017 | 06:51 PM
Is it that the saddles are in the wrong place or they just need to be opened a bit?
Old Jan 25, 2017 | 06:54 PM
IN the picture, it looks like it needs to be opened up:
Old Jan 25, 2017 | 07:26 PM
jpc647's Avatar
I could probably just open them up, but I don't want to have it crack and break off if I try to slowly pry it open.
Old Jan 25, 2017 | 07:33 PM
tru-blue 442's Avatar
Old School Olds
JPC. I also have a 2 row copper unit, PM me if interested, $50 + the ride.
I'm with you on the plastic tanks, they suck.. I have 2 behind the shop, both
have cracked tanks.
Old Jan 25, 2017 | 09:13 PM
It won't. Back in the 80s I bent mine open (well, it was mostly hammering) for a 4 row radiator I had borrowed from my brother in law's 68 GTO, then closed them back when I had my original 3 row end tanks fitted with a 4 row core.
Old Jan 25, 2017 | 09:17 PM
... I don't want to have it crack and break off if I try to slowly pry it open.
It's really no big deal, and it's invisible.
Another alternative is to use a razor knife and cut a channel into the rubber, which will reduce the amount of bending needed.
Old Jan 27, 2017 | 05:56 AM
jpc647's Avatar
Roughly what did that cost to have done?
I did a little bit of both. I'm going to use different rubber feet if I use the Aluminum radiator. Although one of the holes in the passenger side foot(where the rubber snaps into) was a bit rotted and broke off(no problem, I can epoxy the rubber back in place to hold it), but hammering and bending it out might not have been the best idea.
I have to swap it out again, because it leaks at the head under the cap. These friggen plastic tanks really are junk, aren't they!?
Old Jan 27, 2017 | 11:07 AM
It's been a few years so I don't remember the exact amount but it was under $250.
I never had any issues with the replacement plastic/aluminum radiators on my newer cars. And the original one on my Jeep survived 14 years of brutal Arizona 110+ summer heat and serious off-road use before it started leaking.
Old Jan 27, 2017 | 01:00 PM
jpc647's Avatar
Whoa. My local guy quoted me $429 to re-core it out to a 3 row radiator, re solder the outlets, etc. I just can't. I'll warranty the plastic one and give it a final go. Luckily it's winter time, and the car is just sitting anyway...
Old Jan 27, 2017 | 01:02 PM
If you are really that unhappy with it, just send it back.
Old Jan 27, 2017 | 05:47 PM
The one in my old Jeep Grand Cherokee lasted 250,000 miles before the seam started to leak.
What's the longest you've heard of a brass radiator going?
​​​​​​​- Eric
Old Jan 27, 2017 | 08:45 PM
jpc647's Avatar
But what would I get? The copper one is 1/2 thinner. so the rows are very narrow(part number spectra cu351). so it's either this, or one of the custom jobs like champion. At least these have a lifetime warranty through the parts store(which it seems like I'll be needing).
​​​​​​​- Eric
Interesting. The spectra one's aren't built too well though. I'll take some photo's tomorrow for reference.
Old Jan 28, 2017 | 05:04 AM
Is it leaking at the overflow due to a bad cap or because it was overfilled and puking when hot? Is there a deformity in the seating area causing the cap not to seat?
Old Jan 28, 2017 | 07:43 AM
https://m.summitracing.com/parts/sum-380457#
If mine doesn't measure up, this will get the nod, very good reviews, one after a couple of years being used. I considered Griffin but there are too many that leak. In the defence of the plastic tanks, mine was 20 years old and had 350,000 km. They just look like *** in classic cars.
Old Jan 28, 2017 | 10:27 AM
jpc647's Avatar
Good suggestions. But it's actually that there is a small crack on the top of the tank.
Interesting. It's a bit expensive(I was really hoping to stay at or under $225ish, but I do like that it has a nipple for a water temperature sender and the good reviews. I may have to make my own craddles for it too, like the other reviewer did. Which honestly, at this point, wouldn't be the worst thing ever. Mine are a little rotted, and though I cleaned them up and the paint in drying, the next time around, should this radiator fail or leak, I'll replace the saddles too. I'll just break down and buy the repro ones(or make my own).
coldwar
Feb 20, 2014 01:09 AM
drjr56
Nov 12, 2013 09:22 AM
navvet
Sep 25, 2011 11:51 AM
ent72olds
May 9, 2010 06:55 PM
citcapp
Oct 8, 2009 02:00 PM
