BBO to SBO Swap
Old Nov 10, 2021 | 07:32 AM
Thirdcoast's Avatar
Question BBO to SBO Swap
I am trial installing a 350 SBO into a 1964 Cutlass that had a 455 BBO in it.
Upon initial installation, using the same motor mounts (2261) it seems that the SBO sits further forward than the BBO did.. such as more space between the block & firewall and less space between the water pump and radiator with electric fans. I know that the dimensions are different, but this kind of surprised me
It all seems to fit, but is different so I thought I would ask the brain trust.. Is This Correct??
Thanks,
Thirdcoast
Old Nov 10, 2021 | 08:26 AM
66SportCoupe's Avatar
Are you using the correct 64 water pump and radiator or a later version of either?
Old Nov 10, 2021 | 09:07 AM
Thirdcoast's Avatar
Water pump is newer with inlet on pass side..it is the 6" pump.. I may change it later to the shorter pump, but did not want to mess with it for now,.
Radiator is a new Griffin with fans, but made to original dimensions.. dual Spal Fans
Everything hooks up, just trying to find out if the space at the back of the block is usual..
The BBO fit ok, but just had more room at the front and less at the back.. just the opposite with the SBO..
Old Nov 10, 2021 | 09:33 AM
Need to use the short 5.1 inch pump. 6 inch one will not work on early cars up to 67
Old Nov 10, 2021 | 09:59 AM
Thanks,
Thirdcoast
It sits forward because you bolted the motor mounts to the wrong bolt holes in the block. There are THREE motor mount bolt holes on the side of the block. The J88 mounts bolt to the FRONT two of those.
Old Nov 10, 2021 | 12:07 PM
Thirdcoast's Avatar
Joe,
I showed this picture and your reply to my shop guy and he said that this is a Cutlass/Midsize not a Full Size?????
I also do not know what a J88 is ??
Sorry, just trying to get this right,
Thirdcoast
Old Nov 10, 2021 | 12:20 PM
Joe,
Thirdcoast
Wait, you have a Cutlass? Sorry, I'm mixing up threads.
Old Nov 10, 2021 | 08:54 PM
Just curious. Why pull the 455?
Old Nov 11, 2021 | 07:39 AM
67OAI's Avatar
Old(s)GuysRule
It probably looks shorter at the back by the firewall because the deck height of a 350 is shorter than the deck height of the 455. At the front, post #4 above should answer that.
Sweet64
Dec 3, 2016 08:41 AM
TheBigBlueBoat
Jan 15, 2016 02:49 PM
OldsCool9
Jul 9, 2013 02:00 PM
delta881972
Mar 2, 2010 12:39 AM
shaks 442 clone
Nov 22, 2007 03:39 PM
