BBO "C" Heads on 330
Old March 13th, 2014, 05:21 AM
QS442's Avatar
I went to take pics for a member of the Olds 330 and accessory parts that I was selling. Upon taking off some accessories, I noticed that the heads are BBO "C" Heads. What would these heads do for performance for a 330, if any? or why would these heads be put on a 330?
I don't know history of heads as far as work done. However, the engine sounded great when I purchased it. Wasn't able to drive car because it was wrecked in rear. I bought engine off a guy who stated the car used to be his fathers who passed away. Engine was actually in a low mileage Chevelle. I have recently bought another engine that was rebuilt, however this engine has me very curious now.
Has anyone every put these heads on a 330 or put these heads on a 350, what are outcomes?
QS442 is offline
Old March 13th, 2014, 05:38 AM
The Noob Messiah
txrob779's Avatar
I cant help but am curious. Somewhere I thought I read that these heads could/would swap out. That was denied last month by one member but still wondering where I read that.
My 1966 Holiday Cutlass has 1967 "4" heads on it and it is most definitely a low mileage original engine.
Was reading some Wild About Cars technical manuals about the 10.25:1 330 4V in my car...was pretty cool too.
txrob779 is offline
Old March 13th, 2014, 05:45 AM
QS442's Avatar
Yes, I'm very curious to see how it would move a car.
QS442 is offline
Old March 13th, 2014, 05:51 AM
oldsmobiledave's Avatar
curious
Are you 100% sure that the casting letter is a C & not a number 6?
oldsmobiledave is offline
67 Cutlass Freak's Avatar
BB heads on a SB
This has been done before with mixed results. If you bolt the stock BB heads on a stock SB you will lower the compression ratio by at least a full point. At least the old performance 330 engines had close to 10:1 compression to begin with, so now you're at 9:1, or less. A lot of guys that have had success with this modification have milled the heads down to SB combustion chamber size. The other option would be to use high compression flat top, or dome pistons. The other problem comes in with the intake manifold port mismatch. There's approximately 1/4" of height difference from SB to BB. You might want to contact Smitty about this. It sounds like he's had some pretty good success with his in the past- http://www.mjproformance.com/
67 Cutlass Freak is offline
Old March 13th, 2014, 06:35 AM
QS442's Avatar
Yes I am 100% sure. Heads stamped C and the inner color on them are blue.
QS442 is offline
Old March 13th, 2014, 06:39 AM
QS442's Avatar
Originally Posted by 67 Cutlass Freak
This has been done before with mixed results. If you bolt the BB heads on a stock SB you will lower the compression ratio by at least a full point. At least the old performance 330 engines had close to 10:1 compression to begin with, so now you're at 9:1, or less. A lot of guys that have had success with this modification have milled the heads down to SB combustion chamber size. The other option would be to use high compression flat top, or dome pistons. The other problem comes in with the intake manifold port mismatch. There's approximately 1/4" of height difference from SB to BB. You might want to contact Smitty about this. It sounds like he's had some pretty good success with his in the past- http://www.mjproformance.com/
Thanks for that info man.
QS442 is offline
Old March 13th, 2014, 07:04 AM
captjim's Avatar
This assumes that the heads have nor been milled, the deck blocked, plus gasket thickness. You can't say he is under 9 to 1, he might be, but you just can't say so definitively without measuring everything.
captjim is offline
Old March 13th, 2014, 09:01 AM
The use of BBO heads on an SBO has come up regularly. As noted, unless you mill the heads and/or use different pistons, CR will drop significantly (80 cc nominal chamber size on the BBO heads vs. 64-ish cc nominal chamber size on the 330 heads). The BBO ports are larger, so only certain SBO intakes have enough material to be ported to match. Of course, if the intake hasn't been ported to match, the flow disruption will pretty much negate any benefit from the larger ports. Also, BBO heads typically have larger valves than SBO heads - although it is possible to cut SBO heads to fit BBO valves.
joe_padavano is offline
Old March 13th, 2014, 10:43 AM
QS442's Avatar
Engine doesn't have an aftermarket intake on it and appears to be stock. Do 330 intakes have enough material to port?
QS442 is offline
Old March 14th, 2014, 02:17 AM
DoubleV's Avatar
Wouldn't the larger big block sized ports also reduce port velocity causing the engine to be very lazy on the lower end? This has always been my understanding.
DoubleV is offline
Old March 14th, 2014, 06:04 AM
stan 65 cutlass's Avatar
can you post pics of the engine and numbers?? theres a 425 with 330 numbers? what makes you think its a 330?
stan 65 cutlass is offline
Old March 29th, 2014, 09:47 AM
67442nut's Avatar
Easy to tell visually.
Been a while since I've measured them, but, as I recall
small block intake width is approx. 11", big block is 13".
67442nut is offline
Old March 29th, 2014, 10:58 AM
Easy for you, not necessarily the OP.
MDchanic is offline
Old March 29th, 2014, 11:51 AM
Actually, it is. I'll reuse this photo from the other thread. Note the rib between the oil fill tube and the casting number, just to the left (in the photo) of the finger. All BBO block castings have this rib.
Now note this SBO block casting, which has no rib. All SBOs are missing the rib. And no, that's still not my finger...
Old March 29th, 2014, 11:53 AM
Okay, fine.
NOW it's easy for him.
MDchanic is offline
Old March 29th, 2014, 02:15 PM
RROLDSX's Avatar
So does a 350 head fit on a big block? I realize the valves are smaller but a larger valve 350 head with a smaller combustion chamber would increase the compression ratio on a smog engine, assuming they fit and the ports can be enlarged.
I also realize this may be a stupid question.
RROLDSX is offline
Old March 29th, 2014, 02:48 PM
It's a question that gets asked a lot. Again, ALL 1964-1990 Olds motors have the same bore spacing and same head bolt locations, so yes, allowing for the 7/16" vs 1/2" head bolt differences, all heads will bolt onto all blocks.
Is it a good idea? Not particularly. The benefit of higher CR is more than offset by the small ports and mismatch at the manifold. You can't open the SBO ports to BBO size, so there will be a restriction. In addition, without careful blending work at the opening, the mismatch at the manifold will cause a flow disruption that will probably make this motor perform worse than with the original BBO heads. It's been tried, people have made engines run with SBO heads on BBOs, but by the time you're done with all the machine work, larger valves, etc, you're far better off both financially and performance wise to just get a set of ProComps ported by Bernard Mondello.
Old March 29th, 2014, 03:44 PM
RROLDSX's Avatar
Your response is once again appreciated.
RROLDSX is offline
QS442
August 12th, 2014 05:56 PM
odddoylerules
April 21st, 2014 05:07 PM
MDchanic
Wheels and Tires
22
August 4th, 2011 10:23 AM
81 regency
April 21st, 2011 06:18 PM
urnightshiftpal
November 4th, 2010 01:37 PM
Quick Reply: BBO "C" Heads on 330
