Anybody have part numbers on waterpumps for a 70 cutlass 350?
Old Jun 9, 2011 | 01:26 PM
Kidcutty's Avatar
Easy Does It!
Hey guys Im going to replace the water pump in my 70 cutlass with the 350 and want to know if anyone here knows where to buy from.I tried ebay but there are alot of different brands and part numbers.What are is good cheap water pump and where can i get it?Can be ac or non ac.
Old Jun 9, 2011 | 02:58 PM
OldsManNJ's Avatar
1971 Cutlass S
try here - http://www.opgi.com/c/cutlass/1970/parts.html
I use OPGI a lot - and I know a lot of others on here do to. I am sure you can get one elsewhere, I'm just trying to help you out.
Old Jun 9, 2011 | 09:43 PM
2blu442's Avatar
I like Rockauto for mail order stuff like this. But there's also something to be said for your local parts store. If there's any doubt about which pump you need I'd pull the old one off and take it to your local parts store to match it. Remember, two of the three lengths are close, but not close enough for the pullys to line up John
Old Jun 12, 2011 | 07:11 PM
Kidcutty's Avatar
Easy Does It!
re
thats what i found out,pullies dint line up luckily i cleaned it up and returned it but I still dont know which one it is.
Old Jun 12, 2011 | 08:14 PM
OLDSmobility's Avatar
Try this link:
http://www.oldsmobility.com/oldsmo/v....php?f=6&t=391
Old Jun 12, 2011 | 08:15 PM
2blu442's Avatar
Kidcutty, if you still have your old one use this thread to identify which one you need.
https://classicoldsmobile.com/forums...p-lengths.html
Then I wouldn't focus on the casting number, but go into your local autoparts store, NAPA, Baxter, whatever you have that carries a good inventory and try to match it on the counter before taking it home. The main differences will be length. The 1964 had the radiator hose on the other side, then late 1970's (?) had some without both heater hose nipples. Except for those two things all you need is the right length from timing cover to where the pully bolts on. John
Vader
Sep 11, 2014 06:42 AM
Vader
Nov 15, 2013 02:50 AM
Vader
Aug 8, 2013 05:13 PM
miko442
May 14, 2013 09:52 PM
STR-8_CHARGIN
Aug 3, 2010 07:46 PM
