Any Info please!!!
Old Apr 27, 2007 | 01:34 PM
troys2222's Avatar
Any Info please!!!
Another head Question , Ok here goes I have a 69 350 with # 5 heads I just purchased today from craigslist what is either a 350 0r a 403 with a big bore quad carb 2 barrel and egr and with h.e.I and with # 5 A heads I hered a lot of talk about the # 5 heads but have not seen anything on the #5A anyone with info please help!!! I'm going to clean up and get engine #s.
Thanks Troy.
Old Apr 27, 2007 | 04:25 PM
The 5A heads were used on the 307, so I think you got hosed. In the future, check the FAQ at 442.com for casting numbers first:
http://www.442.com/oldsfaq/oldsfaq.htm
By the way, what's "...a big bore quad carb 2 barrel..."?
Old Apr 28, 2007 | 06:11 AM
troys2222's Avatar
hosed again , thanks
well that realy stinks paid $ 60.00 dollars. The carb looks like a rochester quadrajet carburator 4 barrel but only a two barrel.
joe are thier any parts that will fit the olds 350 if so what?
thanks Troy.
Old Apr 28, 2007 | 10:04 AM
thanks Troy.
That carb is one version of the DualJet. Early ones came with the full Qjet body but the secondary air valve holes blanked off. Later ones had the casting truncated to just the primaries. Usually used on a 260, so I'm wondering what you have exactly. Is the intake an aluminum A4? If so, that's a popular swap onto earlier motors.
Other external parts should swap. The crank is interchangable for a 350 crank, though it would need to be rebalanced for the heavier pistons.
Old Apr 28, 2007 | 11:28 AM
troys2222's Avatar
dualjet and y intake
First tanks for all the help, as you can guess i'm not a mechanic-haha- so thanks.
yes it is a dualjet carb the same size as a Qjet the intake is a Y and the heads 5A. Will this intake work well on a 350 or are the ports wrong and if I can use a 4 barrel carb with it A Qjet or a holley?
Thanks Troy.
Old Apr 28, 2007 | 12:57 PM
Thanks Troy.
Are you sure it's a "Y" intake? That would designate a big block manifold. Can you find the actual casting number?
Old May 2, 2007 | 06:14 AM
Jim's rare 80's Avatar
Jim's rare 80
350
Hi. First, look at the top front of the engine, behind the water pump. Next to the oil pressure switch. Let us know the number that is casted into the block. Should be six didgets, a space, then a letter, or number. That will say what block you have. Also, if you have #5 heads, they are from a 68-69 350. The #5a heads are from a 80-84 307, but have the same cc's as the #5. Look for the casting # on the heads between the valve cover and the exhaust manifold, should be 3317 for the #5a. Let us know what you find.
Jim.
sx455raidercelticfan
Aug 1, 2010 08:03 PM
viper771
May 31, 2010 12:40 PM
LangfordBoy
Dec 20, 2008 06:51 AM
jjnine77
Mar 2, 2008 01:11 PM
Dernst_Ca1
Apr 19, 2006 12:00 PM
