Alternator Bracket SB 350 w/AC
Hey,
What is the purpose of the alt bracket that connects to the intake, head and main alt bracket? The main bracket is connected to the top of the alt and the bottom connection has the tension adjustment bolt and it seems a sturdy as needed with just that main bracket. I guess GM had their reasons for it but I've seen plenty of other cars with just a bottom and top bracket and no additional brackets for bracing or whatever. Does anyone know the purpose other than just extra bracing? Does it need to be installed?
Thanks,
Rob
Thanks,
Rob
Hey,
Thanks,
Rob
Thanks,
Rob
My experience w/ that bracket is on a/c cars that have most of the time had the a/c deleted or engine being used in another chassis. Under hard rapid acceleration or as rpm climbs insay, passing gear, the alt belt would start to slip & squeal. I think when brkt is not present the alternator gets pulled inboard enough to allow it to slip, especially if you are winding more than 4-5k rpm. I have used that bracket (in modified form due to tall valve cover height) to solve reccurring belt squeal. You may notice that by '72 (not sure about '71) they reconfigured that bracket but the effective support is still there.
If you care or others interested, you can see the modified brkt in engine shots from my post in this thread. Clearly visible on engine in blue car. Blue car has VC spacers, red car has tall covers so stock brkt won't clear them.
http://www.oldspower.com/vb/showthre...ighlight=stray
If your talking about the rear support bar then GM used that for years across the engine lines. I've seen pretty much every v8 GM made with that brace and never heard of any issues until people started taking them off. On the LT1 engines from the 90's removing that brace would eventaully lead to the primary bracket cracking in half since it was made of aluminum and couldn't deal with the constant flexing.
442mark
September 30th, 2017 01:06 PM
xerxes600rr
August 30th, 2011 06:43 AM
